clicking noise on idle/accel transition
Old Jun 15, 2009
brokedown711's Avatar
brokedown711 is an unknown quantity at this point
Picked up an 03 es1 last week and I noticed a "click" noise that happens after idling and then acclerating. It's only on this transition, is not repetitive (not a rotating noise like with the engine)
I was thinking compliance bushings?! I had it looked at and the tech said it seems to be the axles and I could unbolt them and grease the splines since thats a common problem and he's had brand new cars in that do the same thing.
What do you guys think?
Old Jun 15, 2009
Re: clicking noise on idle/accel transition
anyone?
Old Jun 16, 2009
ridebmx1664's Avatar
ridebmx1664 is an unknown quantity at this point
I think I have the same problem on my 04. Almost a ticking sound. Not like a metronome. But it almost speeds up as the car speeds up. Mine stops at about 40 or 50 KM/h. Someone told my is was the CV joint? the boot around it is worn?
Dont know if that helps at all. But I want a answer as well lol
cheers
Old Jun 17, 2009
mine isn't repetitive, or speed dependent, so im thinking CV joint is not the problem. it's literally one or two "clicks" when the axles are torqued from idling
easy way for you to test if yours is caused by the axle/cv is to crank the wheel to either side and drive in reverse (then try the other side).
Old Jun 17, 2009
BlueEM2's Avatar
Whachya lookin at?
If your moving very slowly while turning your wheel (IE. backing out of a parking spot). can you hear it?
Old Sep 9, 2009
coolhonda's Avatar
coolhonda is an unknown quantity at this point
Question Re: clicking noise on idle/accel transition
My 2000 civic did this last week, and also on reverse. No repetition just click to move off. I took it to dealer service, they recommend replace L/F axle assembly. They said it will get louder but otherwise not urgent or life threatening. I had noticed that my right front tire was low for a while but kept forgetting it, yesterday I filled it, it was almost flat. THE TICK HAS GONE. Does this make sense to anybody?
Old Sep 11, 2009
madAd's Avatar
madAd is an unknown quantity at this point
Sounds like maybe just a little bit of looseness in your CV, or the diff rings. Grease in the spline might help to take out any slack that's there, and quiet things down.
When my car was still under warranty it made a clicking sound when I turned to, the right, I think. But more of a constant sound while at a slow speed. They said they had to replace something in the trans. Mine's a manual though, I don't know what yours is.
WaryDriver
Aug 22, 2015 06:50 PM
Green02civic
Jul 27, 2015 10:48 PM
Smokahontas123
Jul 22, 2015 10:07 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
