Dimmer doesnt work
Old Apr 23, 2009
D911's Avatar
D911 is an unknown quantity at this point
Dimmer doesnt work
Alright, So i've searched the forums up and down for my problem of all my dash lights being out, and ive checked every fuse, incl. "backup" and "small lights" and then i searched stuff up on the dimmer wire being improperly attached when installing a deck (ooops, guilty of that) but i disconnected the wire, and still nothing. I tried to find an answer to what actually happens when you incorrectly attach the dimmer wire, but couldnt find anything.
Anyways, the one light behind my trip/odo works when the light switch is not switched on, but once i switch up, that light goes off, and nothing else comes on. ie. Backlighting HVAC controls etc.
I also took out the cluster and tested the bulbs, and the all came up good,So Ive determined its the Dimmer switch thats faulty, however i dont know any way to fix it.
If someone can point me in the right direction that would be stellar.
Old Apr 24, 2009
Re: Dimmer doesnt work
it fries the dimmer switch. you need to install a new one from junkyard, or get a cheap cluster on ebay and use it for parts. i know someone has done it successfully. i believe you just remove the old one and solder on the new one. if youre somewhat good with electronics, its possible. otherwise just replace the whole gauge cluster with a different one but be sure it has the same or nearly same mileage as your current one.
Old Apr 24, 2009
D911's Avatar
ah well then there we go
The junkyards around my place dont really carry anything newer than like 2000, so i'd be hard pressed to find a 7th gen. Guess i'll be lookin up ebay.
werdnahall
May 17, 2015 11:37 AM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
civic_gt
Apr 19, 2015 08:15 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
