clutch to floor after clutch install?
Old Mar 25, 2009
funch1224's Avatar
funch1224 is an unknown quantity at this point
just finished a clutch install on my friends 2002 ex. everything seemed to go in fine and now the pedal goes to the floor and stays there. what could i have done while doing the install that would cause this?
Old Mar 25, 2009
phil6006's Avatar
phil6006 is an unknown quantity at this point
Re: clutch to floor after clutch install?
cable too long?
Old Mar 26, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Bleed the clutch line. 1. Open clutch fluid res. 2. Take piece of rubber/silicone hose and attach it to the bleeder on the slave cylinder. 3. Stick other end in the res. 4. Keep res. full and pump away. When bubbles stop coming out, the pedal should start to feel stiffer. Retighten bleeder and drive away into the sunset.
Old Mar 26, 2009
funch1224's Avatar
Thanks for the help im going over to bleed it in a couple hours. I'm really hoping this does it.
Old Mar 26, 2009
funch1224's Avatar
ok so i went over and bled there and bled the clutch...alot. Still no pedal. So i took the boot off the slave cylinder to find fluid. Slave cylinder is shot right? Can it just be coincidence that this happened to fail right after the new clutch was installed?
Old Mar 27, 2009
baron340's Avatar
Well that would do it then. If you have fluid coming out from the boot on the slave then its shot. They aren't that expensive though. It is fairly common, especially if the slave was old and you upgraded to higher pressure clutch.
Old Mar 27, 2009
funch1224's Avatar
thanks for the info hopefully this does it
begogadashi
Jun 11, 2015 04:04 AM
Blazz
Jun 4, 2015 01:04 AM
bsmiley
Apr 27, 2015 01:27 PM
meels808
Nov 20, 2001 09:37 AM
Guy01
Nov 6, 2001 06:58 PM
