Idle vibration, LX 2001
Old Feb 8, 2009
tempo's Avatar
tempo is an unknown quantity at this point
Good day! I have a Civic LX 2001, 117K. Until yesterday when I started the engine it had about 1000 rpm, then it dropped to 700-750 rpm. Now it starts at 1000 rpm and goes lower to 600-650 rpm. The car vibrates a lot. When I shift from P to R it stops vibrating for a second and then vibrating gradually increases, same for P to N, and N to D (and has no change between D to D3 or 2). I do not notice any changes in acceleration or power at high speed , however, the engine does not sound quite right. The actual vibration is only noticeable when I stop at a stoplight. It is not engine mounts, I've just changed them. Please help!
Old Feb 8, 2009
Re: Idle vibration, LX 2001
sounds like you may need to clean the intake system. in particular, the iac valve on the throttle body. its the piece where the two coolant hoses go into. remove that and spray inside with carb cleaner to get out any black carbon and junk.
Old Feb 14, 2009
tempo's Avatar
Thanks, that helped.
mistermenphis22
Jul 13, 2015 04:43 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
cgavin1
Jul 7, 2015 07:10 AM
robbie374
Jul 7, 2015 02:56 AM
671civicLX
Jul 4, 2015 04:02 PM
