7th gen help!
Old Jan 24, 2009
em2civicman's Avatar
em2civicman is an unknown quantity at this point
Exclamation 7th gen help!
ok, i know this is a repost, i found the same thing somewhere on the site before but cant find it again...my 02 civic ex 104,000mi keeps over heating!!! i changed the thermostat 3 times got a 195 (cold in NH) changed the coolant antifreeze twice and got all the air out (shop done) and water pump is fine... but it only over heats when im at a stop light or slowing down?!?!?! any ideas plez help?! in college and dont have a lot of $$$....
-john
Old Jan 24, 2009
vicaphit's Avatar
vicaphit is an unknown quantity at this point
Re: 7th gen help!
I am no expert, but if you car is overheating only when you are stopped it could be a fan issue. When you are driving down the road you have constant air moving past the radiator so it won't get as hot.
Old Jan 24, 2009
greeen01civic4d's Avatar
Re: 7th gen help!
i would say fan too
Old Jan 25, 2009
TRIZ's Avatar
Re: 7th gen help!
fan for the win... or loss in your case. Check if it comes on when your parked. If it doesnt and you over heat... your fan is out- check the wiring and get a new one.
Old Jan 27, 2009
Re: 7th gen help!
ok, well fan does turn on...and i dont have a cracked head-gasket that i no of cuz my oil isnt chocolate milk looking....any other ideas? i think im just gonna spend the money and go the the honda dealership.... sux being in college and all
Old Jan 27, 2009
TemjinX2's Avatar
Re: 7th gen help!
maybe check and make sure you dont have any air bubbles in the radiator. Basically just rebleed the system see if it helps.
Old Jan 28, 2009
Re: 7th gen help!
any other opinions? plez anybody? i need help bad, its driving me insane!!!!
Old Jan 28, 2009
Re: 7th gen help!
well turn the a/c on and see if both fans come on. if they dont, theres the problem.
Old Jan 28, 2009
Geek-Squad-Man's Avatar
Geek-Squad-Man is an unknown quantity at this point
Re: 7th gen help!
Plus one on the AC test-
the car has a little temp sensor (usually in the head) that activates a relay and then the fan.
Typically ONE fan motor comes on for engine temp control, but BOTH come on for AC.
When you switch on AC it over-rides anything the normal temp sensor or fan relay does and forces them on.( regular temp relay and or sensor could still be very bad)
- ALSO, don't rule out head gasket just because there's no water in your oil or there's no oil in you radiator, you can get a hair-line crack in the head or gasket and purely just leak a small amount of compression (fire and heat)into one of the water passages. It's rare, but CAN happen-
Usually you can completely rule-out bad or cracked head or head gasket by doing a compression test and visually reading all the plugs, if there's one that's leaking into the water jacket, it will look VERY different than the other 3.
Good luck!!! You are among friends who care about you!!! LOL
Dont keep driving it while its getting hot, you will FOR SURE smoke the engine!!
(warp the head, or the block) (cause it to start burning oil pre-maturely) or something even worse-
Fix it now, dont keep driving it- please!
Old Jan 28, 2009
Re: 7th gen help!
how do i do a compression test again? and i will do the fan thing just i dont want it to overheat...thanks for the help man....^^
Old Jan 29, 2009
Re: 7th gen help!
you're not gunna like the answer:
you remove each spark plug-
you insert a compression testing gauge into each hole, one at a time
crank the motor (the same amount of times each hole)
Hh,huh uh, hu, er uh,.... I said "hole"
write down the results
post them on here so we can all laugh
(that last bit is kinda optional)
GOOD LUCK!
Old Jan 30, 2009
Re: 7th gen help!
ok, fans do turn on...i no that, i saw, BUT only when a/c was on and both were going...i was told that it couldnt be a head gasket cuz it would overheat right away not after driving for 45 min or so (this true?), becuase like i said it only overheats after a while...well any other help? taking it to garage next friday and only got so much $$ being in college... thanks for all the help guys! and Geek-squad-man, not imature about the hole thing...im going to do this probally mon when its warm (warm here is 40 F)
Zygrene
Mar 22, 2016 12:36 PM
HondaGuy7
Feb 22, 2016 01:00 PM
Nalmonte
Sep 28, 2015 01:10 PM
John2009
Sep 10, 2015 09:53 PM
Donahue
Sep 8, 2015 10:43 AM
