Check Engine Light CODE P1259
Old Jan 17, 2009
lunakim's Avatar
lunakim is an unknown quantity at this point
Question Check Engine Light CODE P1259
My check engine light just started coming on. I got my oil changed and it is still on. I went to Auto Zone and they ran a diagnostic and it came out P1259 VYEC System Malfunction
1- Low Oil/Pressue
2 - Blocked Oil Passage
3 - Failed VCT oil control valve
My car has been leaking some oil. The place that did the oil change was too busy to even tell me what was wrong or if anything was wrong.
What should I do, without spending a ton of cash to get it looked at?
My CEL is still on even after the change.
Any help please?
2001 Honda Civic EX 140,000 miles
Old Jan 18, 2009
04 Honda Civic's Avatar
Re: Check Engine Light CODE P1259
Hey you havent gotten any responses and I was looking through the manual I downloaded on this site and searched
"P1259" and it has a pretty good diagnosis on this code maybe you should check it out it goes from the vtec oil pressure switch all the way down to the pcm itself. Good luck
Old Mar 13, 2010
ttkm69's Avatar
ttkm69 is an unknown quantity at this point
where did you download the manual? where can the oil pressure switch and solonoid be found on a 1998 1.6l vtec engine ?
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
