Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
Can I replace 2001 auto transmission with 2005?
Old Dec 1, 2008
tempo's Avatar
tempo is an unknown quantity at this point
Hi,
I have a 2001 Civic LX, SOHC. I have to replace auto transmission. Can I put the transmission from 2004-2005?
Old Dec 2, 2008
Re: Can I replace 2001 auto transmission with 2005?
yup, actually the 04-05 trans is supposly better quality. but all 01-05 auto trans can be swapped with each other.
Old Dec 2, 2008
tempo's Avatar
Thanks a lot for response!!!
Old Dec 2, 2008
tempo's Avatar
Should I worry about engine, if it is from SOHC or VTEC model? I mean can I bolt auto transmission from VTEC to SOHC engine or vice versa?
Old Dec 3, 2008
well the vtec is sohc motor too. it just has different cam and head. but i think the ecu has different shift points for ex and lx. so the trans may be different from vtec and non vtec motors. im not really sure.
Old Dec 3, 2008
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Gear ratios are different in the ex/lx trannys.
Old Dec 3, 2008
BJanzen's Avatar
EX 5M Gear Ratio
First 3.143
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.757
Reverse 3.231
Final Drive Axle Ratio 4.412
EX AUTO Gear Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio (:1) 4.067
HX 5M Gear Ratio
First 3.461
Second 1.750
Third 1.096
Fourth 0.857
Fifth 0.710
Reverse 3.231
Final Drive Axle Ratio 3.208
DX/LX 5M Gear Ratio
First 3.462
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.711
Reverse 3.231
Final Drive Axle Ratio 4.111
DX/LX AUTO Gear Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio 4.067
http://www.fatboyraceworks.com/gears...raph&Compare=1
*Note* Tranmission "A" denotes the gearing of the dx/lx manual gearbox and same goes for "B" and the ex gearbox.
Found that all on another site.
Old Dec 3, 2008
jgcentury's Avatar
Love me some nice, long-lasting vics!
jgcentury will become famous soon enoughjgcentury will become famous soon enough
^^^^ Ratios sure look the same on the auto's to me! ???
Old Dec 3, 2008
kcari's Avatar
has anyone ever done swapped this to confirm?
Old Dec 3, 2008
BJanzen's Avatar
Lol yeah they are, never looked at the auto gear ratios as i have a manual. I know if i ever get a different tranny, im getting a lx tranny.
Old Dec 14, 2008
2001vic's Avatar
2001vic is an unknown quantity at this point
Yes it can be done, I have a 2001 lx and I swapped the auto trans with a manual 2004 trans from a lx. I think for the 2005 is the same thing.
Old Dec 14, 2008
kcari's Avatar
ya but thats manual to auto which i know can be done, but how about auto to auto
Old Dec 15, 2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
it bolts right up, nothing exotic about it, dont stress it lol
Old Dec 15, 2008
kcari's Avatar
just want to be sure - dont want to order something and then it wont fit ya know
Old Dec 15, 2008
ryox82's Avatar
where's the fun in that? Theres nothing more exilerating than taking your car apart to put a new part in only to realize that now, you're pissed off girlfriend will be driving you to work for the next two weeks lol
Old Apr 3, 2009
tempo's Avatar
Well, I replaced 2001 LX auto transmission to 2005 EX today. The initial intention was to switch LX to LX, but, as usual, somebody screwed up and shipped me EX. But as it was said in previous post the shift points are the same. And I drove it today on highway. Hope it will last for a while. I also installed external filter and cooler like Gearbox and other people recommended. Reduction of transmission fluid temperature should help, but nobody knows the statistics on that. thx for all info guys!
Old Apr 3, 2009
good stuff i bet this one will last you alot longer
Old Apr 15, 2009
AntiLoop's Avatar
AntiLoop will become famous soon enough
I have a 2001 civic LX auto also...
I think I will need to change my tranny sooon as it is slipping..
Just a question about costs.
How much do the 2004-2005 Used auto tranny's go for?
Also how much do shops charge to put them in?
Thanks in advance
Old Apr 15, 2009
its a big job, usually 1500 for a used trans and maybe another 1500 for labor or more. anywhere from 3000-5000 ive got estimates for. drive it til it dies. mine had been slipping for almost 40k miles and im almost at 100k now it still drives. how much does it slip? if its only 500rpms i say keep going as long as you can.
Old Apr 15, 2009
AntiLoop's Avatar
It has been slipping for maybe a year now (maybe 20-25,000 km)
I notice it slips the worst from 2nd to 3rd...
Usually goes away once the car is fully warmed up....
Old Apr 16, 2009
yup theres no problem then. that is the most common slip from 2-3 due to defective secondary clutch pack. if it goes away when warm, i dont think you have anything to worry about for a long time. when the fluid is too cold it is thicker and cant get between the parts as easily.
Old Apr 22, 2009
tempo's Avatar
Sorry for delay. You can find used transmission for $900-1100 from local auto recyclers with ~40-50K mi on it. But do not get earlier than 2004. You can also try to order it from on-line store. It takes about 4-6 hr to replace the transmission by mechanic at 65-85 $/hr. So it brings us to $1250-1600 plus ATF cost. If you want to install external filter and cooler it is additional ~ $100 parts+100 work. You can save on work if you install filter and cooler by yourself.
Old Sep 9, 2015
Mariano falcon's Avatar
Mariano falcon is an unknown quantity at this point
Mariano, so i know its been a while since your swap but i have a 2002 lx 4 door automatic and have a friend that has a 2004 ex 2door how did your transmission work? Should i swap it?
Old Oct 19, 2017
Jayrick99's Avatar
Jayrick99 is an unknown quantity at this point
Can i use a LX auto transmission with a EX engine?
Old Oct 19, 2017
yes you can. However, given the EX's transmission has a shorter gear ratio than the LX/DX's, acceleration will be slower than a stock EX engine/transmission setup.
Old Oct 23, 2017
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
Will a transmission from Japan work the same as a USA transmission without getting CEL.?
Old Sep 12, 2018
Quacha86's Avatar
Quacha86 is an unknown quantity at this point
So a guy could put a 2003 Civic LX transmission into a 2004 Civic EX? Please I need to know this asap.
Old Sep 13, 2018
Slumpertcivic's Avatar
You could, but you shouldn’t unless you have it rebuilt and upgrade the internal filter to 04-05 version along with new clutch packs.
antrmo
May 7, 2013 11:52 PM
Intercooler
May 21, 2006 09:00 AM
02boostlessCIV
Jan 6, 2005 10:34 PM
CivicMexicano
Jun 10, 2002 05:03 PM
