electrical, lights problems?
Old Nov 3, 2008
o4hondaskivic's Avatar
o4hondaskivic is an unknown quantity at this point
Question electrical, lights problems?
im not sure if this is where im supposed to be posting this...but this is where i posted my problems i was having with my egr system...the problem is that all the lights in my car is pulsating...im not sure how to describe it but its from my headlights, parking lights, break lights, interior lightsand all the dash lights.......is goin dim, bright, dim, bright...thats bout the best that i can explain it...it will do it for about a week or so then go back to staying one solid brightness for a day or 2 ...then it will do it again for bout a week or so....and so on...im not sure what it is...but when it does if im slowly accelerating i can feel the motor kind of in and out with it....but thats only on acceleration...me and a good friend of mine through the car to see if we could find any loose connections or bad grounds and didnt find anything...i took the car and had the altenator and the battery both tested under a load and with out a load... and test results came back good for both.....so it leads me to think there is a short somewhere...thats what im guessin...anyone with any ideas...or whats the easiest way to track down a short...any ideas will be helpfull and appreciated..thanks again....
Old Nov 3, 2008
Krieger's Avatar
Krieger is an unknown quantity at this point
Re: electrical, lights problems?
sounds like ur alternator isnt working right. the lights dim when the engine doesnt idle high enough to turn the alternator at the right speed... and there is some kinda chip or relay in our fuse box area that causes ur alternator to go either low or high output... ill look for the paper my honda dealership gave me when i had the same kinda thing...
except my lights didnt "pulse".
Old Nov 3, 2008
thanks man i would appriciate it...like i said it does it for about a week or so then it will stop for a day or so..then about a week or so and then stop for a day or so...and so on..i just need to get it fixed and i have no clue where to begin if it is a short...
Old Nov 6, 2008
WannaBFast's Avatar
Prowlin' with a Purpose
could be the alternator, electronic load detector, or could be the battery...
CarStuff
Dec 6, 2020 12:52 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
WLakers
May 4, 2015 06:23 PM
SSMatey
Apr 13, 2015 06:09 PM
