Civic gearing and gas mileage
I have 2002 Civic EX 5spd. My brother-in-law has a 2001 EX with an automatic.
He claims his runs at:
~2800 RPM @ 70 MPH
~3100 RPM @ 80 MPH
mine runs at:
~3400 RPM @ 70 MPH
~3900 RPM @ 80 MPH
Are they really that much different? (OD in an automatic vs. 5th gear in a manual)
I love driving mine around town here in Duluth, MN (which is a very hilly town) as I get about 35 mpg. But, when I get out on the highway, I get worse mileage unless I only drive 60 MPH. Maybe its just not a great highway vehicle but I was really surprised at the difference in RPMs at the same speeds.
~2800 RPM @ 70 MPH
~3100 RPM @ 80 MPH
mine runs at:
~3400 RPM @ 70 MPH
~3900 RPM @ 80 MPH
Re: Civic gearing and gas mileage
What I meant was, shouldn't my tallest gear (5th) run at the same (or lower) RPMs as his? (since his is a 4 speed automatic).
ie:shouldn't we both be at the same RPMs at 70 mph?
Official Rattlesnake Hunter
i dont know look up the 7th gen gear ratios and compare the two...
ill bet the close to the same.
post the info if you find it.
If you want a higher ring and pinion ratio (fewer rpm's per speed) you could swap out your ring and pinion set with a set from a non-EX model. The EX has a lower (sportier) gearing then all other models. Of course the cost of installation would take you 100,000's of highway miles to payoff in gas savings.
tylerginevan
Apr 27, 2015 12:29 PM
