Tranny Problem--no 5th gear or reverse
Old Jul 21, 2008
jee88's Avatar
jee88 is an unknown quantity at this point
anyone with a 7th gen have a problem with the 5th gear popping out?
pretty much when i shift to 5th, it will only stay in for a few minutes then pop out, after about half hour of driving, it will pop out frequently, as short as 30 seconds, i pretty much gotta hold it in if i wanna drive in 5th, pretty ****kin annoying, and i dont wanna go str8 to a tranny shop not knowing anything about it and get ripped off, just wondering if anyone knows what i could be
Old Jul 21, 2008
Tragedy's Avatar
skate or die
Re: 5th gear problem
could be Honda's fault. Take it to them and make them fix it for free.
Old Jul 22, 2008
jee88's Avatar
i wish i could, but i was the 3rd owner n it happened a couple months after i got it
long story short, i had the balljoint bolt fall off and come out of the nuckle while i was driving, and it all started after i repaired it
Old Jul 29, 2008
jee88's Avatar
bump
Old Jul 29, 2008
FALKEN's Avatar
Civicforums Junkie
moved.
Old Jul 29, 2008
greeen01civic4d's Avatar
there is a tsb about it, its either the bushings at the transmission developing corrosion, or its the shift forks inside the transmission, i have the tsb if u have an email addy
Old Aug 17, 2008
jee88's Avatar
yeah that would be great, my emails jee187@hotmail.com
now it barley stays in 5th at all and it wont go into reverse, and it grinds when i have the clutch ingaged
Old Aug 17, 2008
02Sicivic's Avatar
02Sicivic is an unknown quantity at this point
What a stupid comment, how are you going to make a company fix something for free. "Excuse me Mr. Major Company, I want this fixed for free ok...oh my reason? Because I want it for free."
How long after the BJ fell out did the issue happen? Was it right away(ie: day you fixed it) or was it a few days after?
Old Aug 18, 2008
jee88's Avatar
LOL! nicely said
and it was so long ago, almost a year if not a year.
but it wasnt right away, i think a couple weeks after
and actually right now, it wont go in reverse and will not stay in 5th at all. and it makes noises when the clutch is engaged
i been reading that "diagnosing tranny problems" thread, im only on page 5, and i realized the input shaft berring must be hooped. but would this also cause the gear problems or is there some kind of adjustment, because it only started making noises yesturday
i figured maybe there was some way to adjust something seeing as the right gears are ****ed (5th n reverse)...til i started reading that thread, now im not sure
(also my cars been parked for like 3 months now, just had a 3 day permit on it 2 weeks ago, and a 1 day permit yesturday)
Old Aug 20, 2008
02Sicivic's Avatar
Re: Tranny Problem--no 5th gear or reverse
Have you checked the shifter linkage? Remove the centre console and check to see if anything is binding or catching the cables or shifter.
Old Aug 23, 2008
jee88's Avatar
thanks bud, ill check that this weekend
Old Aug 31, 2008
pacotaco's Avatar
pacotaco is an unknown quantity at this point
hold on ur the third owner of the car right if u are did u get the car this way? for the revers problem i think i might know what it is theres a peice up at the top of the case which if its not seated properly it can cause it to not go in reverse the fifth gear problem might be a shreaded gear maybe im not shure but im shure if its what i think it might be that peice broken because thats what happened to our car it broke and we couldent get into reverse
Old Aug 31, 2008
pacotaco's Avatar
o yeah and your throw out barring might be busted that might be what the noise is when the clutch is engaged
Old Aug 31, 2008
jee88's Avatar
**** dood, really, can u shoot me an email or something and give me a little more info on how to check or what it looks like. @ jee187@hotmail.com TIA
Old Sep 1, 2008
jee88's Avatar
you mean ISB
nirvanaguy
25
Oct 26, 2017 07:26 PM
FistRock
Sep 4, 2015 08:00 PM
dantheman42
Sep 4, 2015 01:10 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Bonnabell
Aug 14, 2015 04:15 PM
