Heater, Rad, motor problem?? Help
Old Jul 8, 2008
minorc's Avatar
minorc will become famous soon enough
Hello, my car doesn't produce hot air through the vents, before and after i got the head worked on. I changed the thermostat and still nothing, also the radiator fan won't turn on unless i use the climate controls inside the car and the lower rad hose is cold while the top hose is burning hot, any ideas? I can see that the coolant probably isn't circulating properly but why wouldn't my rad fan kick on by itself.. i mean i can let the car run for days and it still wont go, its maddening. Help anyone?
Thanks
Old Jul 8, 2008
Re: Heater, Rad, motor problem?? Help
i thought top hose is supposed to be hot, and bottom cold. thats how mine is, the bottom is the one returning from the radiator after being cooled. for the fan to kick on, its gotta be very hot. mine only comes on once or twice when its 90F outside and i let the car idle after a long drive. have you tried bleeding the coolant for air bubbles? you may just not have coolant reaching the heater core. or it might be clogged. or your temp switch may be broken. there is the fan temp switch located very close to the thermostat you could replace to see if that fixes the fan problem. is the bottom hose COLD, or just warm. if it is not warm at all, then prolly a stuck thermostat. i know you changed it, but thats what it is.
Old Jul 8, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
bleed the system completely & go from there.....cooling fans kick on at 97 degrees...takes mine like 30-40mins of idle & short trips for it to come on
Old Jul 9, 2008
minorc's Avatar
Thanks for the advice guys, could be way too many things though. The lack of cabin heat is really starting to bother me, and im driving 8 hours this weeekend both ways so i don't need any problems. I guess i'll take it to a my mechanic. THanks
Old Jul 9, 2008
minorc's Avatar
Well i took it to a shop, took a look at it did some little tests and concluded that something in the cabin of the car is not letting the hot air though the vents, the hoses are hot the heater core isn't faulty its just being blocked by something.. probbaly whatever hte middle button with the cold-to-hot air controls. Is there some sort of door there or cable that may be defective? anyone encounter this at all?
Old Jul 9, 2008
yup i bet its the temperature switch. basically it gets stuck and the lil doors wont move to let heat in. same happened to my bros rsx where it got stuck in hot mode and the ac would not blow cold at all. turns out it was just the switch that went bad.
Old Nov 9, 2008
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
Resurrecting and old thread but...I have heat when I'm moving but no heat at idle. Doesn't matter how hot the coolant temp is, it won't blow heat unless moving or revving high enough...does this sound like the heater core or something else? Doesnt' seem like it would be the door you guys are talking about, since it works with only changes in rpm...
NEVERMIND! Further searching may have solved my issue...
blazebrown
18
Jun 2, 2019 12:31 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
DouglasTheGreat
May 27, 2015 11:23 PM
Supramk3
May 11, 2015 07:55 PM
tylerginevan
Apr 27, 2015 12:29 PM
