2002 civic air coming through the vents
Old Apr 8, 2008
anik's Avatar
anik is an unknown quantity at this point
I drive a 2002 civic dx. when i am one the highway or driving at a higher speed little bit of air comes out of the vents even though the A/C is off. Air is cooler or warmer depending on the location of the ****. What could be the problem? how can i fix it?
Thanks
Old Apr 8, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Re: 2002 civic air coming through the vents
No problem. Every car does it.
The **** controls the thermostat which is a component that when set to cool opens the thermostat, without the AC on air the passes through that is typically the temperature of the air in the engine bay.
When the thermostat is set to warm the thermostat closes a bit which causes warmer air to get into the system.
While driving, this air is forced into the system naturally and some of it comes through the vents even without the fan on.
The fan **** controls the fan which propels the same air faster.
Hopefully that makes sense. You can close the vents if you like.
Old Apr 8, 2008
2DoorVic's Avatar
2DoorVic has a spectacular aura about2DoorVic has a spectacular aura about2DoorVic has a spectacular aura about
just make sure the orange light is on the switch to the left of the AC switch.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
