Another Broke Fuel Door 2005 HELP NOW!
Old Feb 21, 2008
dryft's Avatar
dryft will become famous soon enough
hi my name is mike
and i have a problem
::audience::"Hi mike!"
i went to the gas station last night and my fuel door broke! i wasn't angry at The time because i wasn't totally sober. but today im furious.
NOW the dealership wants to charge me 80$ to diagnose the problem AND THEN if they conclude its under warranty they'll wave the fee. i asked if i could diagnose the problem myself and discover if the problem was under warranty and they said NO! "We CAN'T GIVE YOU OUR DIAGNOSTIC SECRETS! HOW WOULD WE CONTINUE TO SCREW PEOPLE!" I asked them if they had heard about this common problem in our generation of civics and they had no idea what i was talking about, nor have they heard of the website, "www.fueldoorfix.com".
so im going to use the temporary fix from fueldoorfix.com and then take **** apart tonight to see if that 20$ part from fueldoorfix will work.
CAN ANYONE TELL ME WHAT EXACTLY BROKE PIECE I SHOULD BE LOOKING FOR TO KNOW IF THE 20$ PIECE FROM FUELDOORFIX.COM WILL WORK, AS THEY DO NOT EXPLAIN THAT ON THEIR SITE, THANKS
Old Feb 21, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: Another Broke Fuel Door 2005 HELP NOW!
fuel door fix i can vouch for...
its legit and sounds like your problem
Old Feb 21, 2008
dryft's Avatar
ok, let me explain this again.
when i push down the lever to release the gas door there is no pressure while pushing it and the gas door sounds like it makes no attempt to open.
NOW, when i take the lever apart tonight like it explains in the video on fueldoorfix.com WHAT IS THE BROKEN PIECE I SHOULD BE LOOKING FOR THAT FUELDOORFIX.COM CLAIMS THEY CAN FIX.
for example, if a f*ckin little spider went inside my fuel door and chainsawed everything inside all to hell, THAT would be the broken piece to look for AND fueldoorfix.com's piece couldnt fix that because its on the completely different end of the f*ckin problem!
lol again, any help would be appreciated. =)
Old Feb 21, 2008
02BLKCIVIC's Avatar
[QUOTE=dryft;4289684]ok, let me explain this again.
when i push down the lever to release the gas door there is no pressure while pushing it and the gas door sounds like it makes no attempt to open.[QUOTE]
yes it will fix this problem...
call fuel door fix and ask them, it may be easier
Old Feb 21, 2008
dryft's Avatar
yeah i sent them an email because they don't provide their phone number on the website so you have to request it in an email. thanks for the help though
Old Feb 21, 2008
02BLKCIVIC's Avatar
no prob good luck,
PS you can open you fuel door throught the trunk if you didnt know
Old Feb 21, 2008
they have step by step instructions and pics. the problem is a weak area near the gas door release lever where the cable just snaps. the fix just allows you to put it back together without buying a whole new cable and running it through your car to the gas door (which will just break like the first one did).
Old Feb 21, 2008
dryft's Avatar
awesome so there is absolutely no point in going to the dealership to have the same defective piece replaced. Why wasn't there a recall on this crap!?
alright looks like im climbin in my trunk to pop the door until they ship the part to me.
i'll rip my car apart tonight just to look at it and double check everything. hopefully i can put it back together since im fairly new to this sh*t
Old Feb 21, 2008
there is a tsb on it i believe. but yeah they do not have any kind of fixed update, they just put in another cable assembly which costs $$$. just take off the sill panel that goes around the trunk/gas release lever and see where the cable is broke.
Old Feb 25, 2008
dryft's Avatar
Angry Re: Another Broke Fuel Door 2005 HELP NOW!
so i broke a lot of trim when infiltrating the broken gas door cable.
its impossible to know where the effin bolts are under the trim you have to pop/slide out! The fueldoorfix.com video is CRAP when you need to figure out the trim! And the video is for a 4 door, NOT A COUPE! AND, the bolt sizes are different
however, i took a lot a lot of pictures of WHAT NOT TO DO, and will be making a DIY for the fueldoorfix for coupe models. i made it far enough to pull the lever set up out underneth the trim, but im gonna have to remove the seatbelt to completely remove the trim and most likely replace it
****in dealership should be able to tell me if its under warranty over the phone.
when i have time to post up the DIY i will post a link in this thread
Old Feb 25, 2008
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I don't know why so many people have problems with these broken cables. Do you yank on the lever or something? Ive got nearly 130k on the origional cable...
Old Feb 25, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Dido! I see em all the time.....I have never managed to break one in any car let alone a civic?
Old Feb 25, 2008
i guess it just wasnt made very well. i havent had a problem yet, but who knows. they shouldve made it like the throttle cable. from what i gathered tho, its not the cable that breaks, its the part that attaches to the release lever.
Old Feb 25, 2008
dryft's Avatar
nah you would be pushing on the lever to open the gas door, pulling is to open the trunk.
BUT, THE REASON I BROKE MINE i believe is because ya'll live in Cali where its nice n hot, i live in md and it gets pretty cold here sometimes. so my gas door freezes shut and the cable can only make so many attempts to open it before breaking
Old Feb 25, 2008
next time try to push on the actual gas door first until you hear the ice break, thats what i do every time lol
Old Feb 25, 2008
dopes6070's Avatar
The cold weather could totally explain them breaking… I diddn't think of that.
Old Feb 25, 2008
02BLKCIVIC's Avatar
I live in arizona, and no problems...
Old Feb 25, 2008
Rufus's Avatar
I order that piece once and it couldn't fix mine as the wire had seperated from the plastic that hold it still. Since the plastic piece wasn't there the fueldoorfix had nothing to hold it in place and I ended up replacing the entire cable (which was only about $30). However, it's a more work than the fueldoorfix method.
Good luck.
Nalmonte
Jun 3, 2015 11:01 AM
MajTom
Jun 2, 2015 11:48 AM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
civic_gt
Apr 19, 2015 08:15 AM
