Rattling/knocking noise coming from head
Old Oct 10, 2007
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
At around 3000 rpms in every gear i can hear a rattle/knocking noise coming from the head cylinder. I have already adjusted the valve clearance and checked the vtec solenoid. When I checked the valve clearance, all of the intakes were pretty tight (.001 or .002). I readjusted to the correct clearance. From what i could tell there wasnt anything else amiss. After putting everything back together the problem persists. Any ideas?
UPDATE-I just went to honda. and they said it sounds like they timing belt is hitting the belt cover. I have a belt coming in the mail tomorrow so it was already getting changed. Anybody encounter this? Do they stretch a little when they are about to break? car has 100k on it
Old Oct 10, 2007
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Re: Rattling/knocking noise coming from head
Wow that’s strange. I've never seen it happen. There is an auto tensioner for the t-belt so it should always stay tight
Old Oct 10, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
maybe the belt jumper a tooth and shifter over enough to come in contact with the plastic cover?
either way...youll be fixing it when the belt arrives so thats great!
Old Oct 10, 2007
You VTEC...I-VTEC
the service supervisor at honda says that the tensioner rarely goes out though.
i should have had you take a listen while i was at your house
Old Oct 10, 2007
dopes6070's Avatar
ya usually the only problem with the tensioner is that the bearing will get rough and make noise.
Old Oct 12, 2007
You VTEC...I-VTEC
so I changed the timing belt and the sound still persists. There wasnt any abnormal wear, broken pieces, or anything else anywhere inside the timing belt area.the only thing I could find unusual was that there were some cracks around the holes where the bolts go into on the lower plastic cover. I dont think it is the cover making noise, but I am replacing it just in case.
Old Oct 15, 2007
You VTEC...I-VTEC
I have now changed the water pump, all the belts, and the covers and still the problem persists. I took the tensioner to the shop foreman at honda and he said it is fine. I am about to go ape **** on my car. I really hope someone crashes into it at this point and totals the car.
Old Oct 15, 2007
speedfoos's Avatar
Have you checked all the spring clips between the rocker arms that keep them spaced? They may be the cause of the jangling if they are loose. Um...I don't know, I'll keep thinking about it though and let you know what I come up with.
Old Oct 15, 2007
You VTEC...I-VTEC
what should i look for in those? They looked fine when i did the valve adjustment.
Old Oct 15, 2007
speedfoos's Avatar
Just make sure they're properly aligned and not terribly loose. Should be obvious if there is something wrong with them.
It's not coming from any of your accessories is it (AC comp, PS pump, alt.)? Let me think.... Does it do this in neutral as well or just drive gears? What about reverse? Might be tranny related unless you can clearly hear it in neutral.
Old Oct 15, 2007
You VTEC...I-VTEC
it does it in all gears, in neutral, and i am putting a new tranny on in the next couple of days. all that is really left that i havent checkd is the block but the noise is definitely not coming from there. Was messing around with it again today. Could possibly be from something in the oil pan and is vibrating up through the motor and thats why i thought it was on top before. What all could end up in the oil pan? I have no loss in power what so ever. still drives and sounds good other than that noise.
i am about to drain my oil in a few minutes.
Old Oct 15, 2007
dopes6070's Avatar
it could be it spun bearing they tend to make a nasty banging noise when they fail.
Old Oct 15, 2007
You VTEC...I-VTEC
when they fail what kind of symptoms would the car have? i would think there would be some sort of performance loss with that. ]
Well i just emptied the oil. nothing in there. no metal of any kind. And my ****ing oil pan decided that it was going to grow a crack on the bottom so i got oil all over my drive way. I am completely stumped
Old Oct 15, 2007
dopes6070's Avatar
any way you can take a vid with the noise?
Old Oct 15, 2007
You VTEC...I-VTEC
yeah i can .... tomorrow though
Old Oct 15, 2007
greeen01civic4d's Avatar
have u thought about using an automotive stethoscope, or chassis ear, to determine where its coming from, instead of throwing parts at it?
Old Oct 15, 2007
You VTEC...I-VTEC
yeah i have one of those, thats what made me decide on the oil pan. all these parts i was going to replace anyways just hoped they would fix the damn noise.
Old Nov 2, 2007
You VTEC...I-VTEC
heres a video with the noise
http://www.youtube.com/watch?v=LjtqaIRYxms
Old Nov 2, 2007
dopes6070's Avatar
hmm thats an interesting one. It kinda sounds like its in the valvetrain or maybe one of the accessories. try taking both your accessory belts off and seeing if the noise is still there. Just dont drive the car like that since your battery will die fast cause no alternator.
Old Nov 2, 2007
You VTEC...I-VTEC
I am actually in the middle of doing that right now. when i take the crank pulley off the sound goes away within 2-3 seconds. but as soon as i put it back on the noise is there
from what i can tell the harmonic balancer doesnt appear to be wobbling any
Old Nov 2, 2007
dopes6070's Avatar
you shouldnt have the engine running with the crank pully off. Thats what holds the timing belt pully on.
Old Nov 2, 2007
You VTEC...I-VTEC
the timing pulley isnt coming off. i check to make sure. it seem like the timing cover is keeping it in place
Old Nov 2, 2007
You VTEC...I-VTEC
well i have already done it, any ideas though
Old Nov 2, 2007
dopes6070's Avatar
what if you leave the crank pully on and press on the timing cover in different places. does the noise change?
Old Nov 2, 2007
You VTEC...I-VTEC
yeah i tried that too.. if the pulley is off i can create a similar noise. when the pulley is on the noise doesnt change
Old Nov 2, 2007
dopes6070's Avatar
hmmm. next I would throughly inspect the whole valvetrain. have you ever missed a shift or anything.
Old Nov 2, 2007
You VTEC...I-VTEC
i am sure i have missed a shift at some point... how would missing a shift cause a problem here? that sounds like it would cause a tranny problem(and as you know i have your tranny installed). by inspecting the valvetrain do you mean taking off the cylinder head? When i did the valve adjustment i inspected everything then.
Old Nov 2, 2007
dopes6070's Avatar
nah just taking off the valve cover off to check all the follower and all that.
Missing a shift and hitting 2nd instead of 4th for example would overrev the engine mechanically as high as probably 9000 rpms which it wasnt designed for. That can cause broken valve springs and such.
Old Nov 2, 2007
You VTEC...I-VTEC
oh no, i have not hit the wrong gear. i thought you meant like a little grindage action.
Old Nov 2, 2007
dopes6070's Avatar
ooh lol nah that doesnt matter much haha. It will eventually damage the trans but it takes a lot.
