Manual window..
Old Oct 5, 2007
hktvb2001's Avatar
hktvb2001 will become famous soon enough
Manual window..
Hi,
I have a CIVIC 2001 DXG 4 doors, and my window is manual. When, I push the stick to scroll down the window, it's easy.. But when I would like to scroll it back up, it's freaken hard. All my 4 windows are the same. Easy to move down, freaken hard to get back up. My friends are complaining about this.
Please help me..
Old Oct 8, 2007
Danil ACE's Avatar
Danil ACE is an unknown quantity at this point
Re: Manual window..
It's called gravity. Easier to lower something than to lift it.
Old Oct 8, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Manual window..
Take the door apart and see what's causing the resistance?
Old Oct 12, 2007
hktvb2001's Avatar
Re: Manual window..
You mean take the inside door out?
Old Oct 12, 2007
DeX's Avatar
DeX
Canadian, Eh!
Re: Manual window..
Take the door panel off dude.
- look inside the actual handle, there's a piece you lift up and there's a screw underneath, use a phillips to get it out.
- about 2 inches from that in the corner of the handle is another screw, get that one too.
- inside the lever that opens the door (12 inches above handle) is another plastic piece you have to pry out with a small flathead and get at 2 screws behind it, take those out.
- unhook lever and remove
- use a flathead to get the C clamp out from in behind the window roller - DON'T LOSE IT! Sometimes it pops off and you only hear the tinging as it bounces down the street.
- put fingers behind speaker grille and pop out. Pop out door all around outside.
- lift door panel off
- finish beer
- inspect
From here you can lift up on the bottom of the window as you roll and see if it's easier.
robjcivic
Mar 12, 2017 12:10 PM
JetsterDajet
52
May 8, 2016 12:11 AM
John2009
Sep 10, 2015 09:53 PM
Christian123456
Sep 9, 2015 05:26 PM
tommycanada
Sep 5, 2015 04:59 PM
