Can I borrow your crank pulley holder?
I live in Columbus, Ohio, can I borrow your pulley holder to replace my timing belt?
4. A crank pulley holder tool which can be purchased here
http://www.etoolcart.com/index.asp?P...ROD&ProdID=629
Thank you!!
Thank you!!
Re: Can I borrow your crank pulley holder?
Bump. I will pick it up from you anywhere about 50 miles from columbus.
Is there any other way to get that Pulley Bolt loose on a civic automatic?
thank you.
thank you.
just put a really big flat screw driver in the flywheel teeth to hold it still while you take the bolt off and put it back on. Ive done it many times. You can either remove the starter or the lower flywheel cover and use the screwdriver in either place.
Bonobo
Oct 2, 2015 06:58 PM
68camerors
Sep 24, 2015 06:18 PM
Skunkone
Sep 24, 2015 04:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
