motor flush with tranny fluid
Old Sep 5, 2007
f1n-5's Avatar
f1n-5 is on a distinguished road
i was in class today and my professor was talking about engine seize(not hydro lock).
he brought up the suggestion of letting tranny fluid sit in the combustion chamber to let it lubricate the walls and etc.
after letting it sit, slowly... turn over the crackshaft.. back and forth back and forth until it moves freely..
he also mentioned that tranny fluid is a great lubricant and cleaner because of all the minerals it carries.. because of that he flushes his motor with ATF fluids.
his process:
drain some of oil(half).
plug the drain plug.
poor in half ATF and let it the motor reach 30km.
drain the motor oil/atf and refill the motor with motor oil.
this allows the atf to clean the block and also the piston rings which could prevent oil from burning.
what do you guys think??
i find it this really interesting and i want to give it a try with my stock motor.
but very skeptical....
Old Sep 6, 2007
jdonline's Avatar
jdonline is an unknown quantity at this point
Re: motor flush with tranny fluid
Hmm I don't know, I've never heard of anyone trying that before. What type of professor is he?
Honda Engine Locater
Mobile, AL
Old Oct 9, 2007
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
sorry to bump an old thread but i was wondering if this true. i heard ppl on socalprelude.com do it. so wouldn't it be fine on our cars. anyone?
Old Oct 10, 2007
MarkM01's Avatar
MarkM01 is an unknown quantity at this point
Your engine doesn't need to be flushed. Don't put tranny fluid in it!
If you want to clean your engine, the best thing for that is http://www.auto-rx.com/ . Nothing else!
Old Oct 31, 2007
EMTwannabe's Avatar
EMTwannabe is an unknown quantity at this point
It's an old school trick that DOES work. Transmission fluid is a detergent. I've never done it myself, but from I've been told you add 1/2 L on top of your oil run it hot and drain.
Old Oct 31, 2007
greeen01civic4d's Avatar
ive heard the same thing, but u may smoke for a while, since trans fluid burns easier than oil
Old Nov 2, 2007
mishqua's Avatar
mishqua is an unknown quantity at this point
I would never try it in a Honda but a cup of disel fuel in a ford does wonders. I was a little skepticle about it and had to do a rebuiled any way so I put in the cup ran it for about a half an hour and it cleaned up that engine looked great.
Old Nov 2, 2007
EMTwannabe's Avatar
I'd never try that either.
Old Nov 3, 2007
f1n-5's Avatar
yup, old school trick.
and this DOES work like you mentioned.. but its better you if you let the tranny fluid run in the engine for about a week or so then flush.
it is suggested that you put 1/3 or tranny fluid and 2/3 of you regular motor oil.
i would try this... but mine engine is fine thank you.
Old Nov 23, 2009
JWMcBride's Avatar
JWMcBride is an unknown quantity at this point
I'm in a business where sometimes engines for sale get "stuck" while sitting up. I don't have this problem personally because I "smog" my engines down, but from talking with industry contacts and in dealing with other people's engines, I've found transmission fluid does a great job of unlocking engines, especially when they're stuck because of light rust around the rings.
However, by far the best solution to unsticking an engine is PBBlaster. If it's really stuck because of light rust, PBBlaster will get you back on the road quick. I say this as someone with 10 years of experience working with engines. Any parts store has PB Blaster in stock, and it has a lot of uses besides unsticking engines. I LOVE that stuff.
By the way, I would love to know what kind of scenario your professor envisioned causing that rust to occur. It's pretty rare!
I hope that helps you or someone in the future.
MajTom
Jun 2, 2015 11:48 AM
usajags84
May 30, 2015 06:49 PM
Supramk3
May 11, 2015 07:55 PM
BootyDo
May 7, 2015 04:46 PM
01LX
Feb 20, 2002 03:14 PM
