Steering?
Old Aug 23, 2007
2k2civicsedan's Avatar
2k2civicsedan is an unknown quantity at this point
Steering?
Hey guys. A few days ago my steering started popping. It only does it when I turn sharp like into a parking spot. Do you'll have any suggestions on what might be causing it? My car is lowered but its been lowered for a about 6 months and the noise just started. Any advice would be greatly appreciated.
P.s. I have already used the search function.
Old Aug 27, 2007
Re: Steering?
So does anybody have any advice?
Old Aug 27, 2007
speedfoos's Avatar
Re: Steering?
Is it the "Tong!" sound? Or something different?
If it's Tong-ing, you need to reseat your springs as they are binding. If its a grinding/popping it could be your CV axle/axles. Check and see if the boots are torn as that can be an indicator that you have axle problems.
Old Aug 28, 2007
Re: Steering?
Its the popping sound. My buddy told me it might be my cv axles but he doesn't know much about hondas so he told me to ask somebody that knows more about hondas.
Thanks for the help.
Old Aug 28, 2007
VinhTEC's Avatar
VinhTEC is an unknown quantity at this point
Re: Steering?
Probably your struts if they are OEM and you have alot of mileage or wear then thats probably the cause. You will have to have some one listen outside as you turn the wheel sharply like you described to pinpoint the noise more than likely you need struts.
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
