Somethings wrong.. Help!
Old Jul 18, 2007
marcuse's Avatar
marcuse will become famous soon enough
Ok so my car has been acting up the past couple weeks. If i drive on the expressway or anywhere for 20ish or so minutes solid, my malfunction light comes on. Once that happens I cannot accellerate past 4k RPMS.... If i mash the pedal it will jump until it hits 4K and then just putz'z and bounces off of 4kRPMS... I really need some help w/ this. Also, my ABS light randomly decided to kick in a little before this happened.
Thanks!!
Old Jul 18, 2007
WKHCivic's Avatar
WKHCivic will become famous soon enoughWKHCivic will become famous soon enough
Re: Somethings wrong.. Help!
I hate to say this but when mine wouldnt go past 4k rpms my tranny blew right after that.
Old Jul 18, 2007
marcuse's Avatar
Sir, I am actually very happy that you said this because, I am piecing together parts for a 5 Speed swap, and was wondering if it was the tranny. In hopes that i could just kill it and the engine wasnt the issue. Keep your thoughts coming!
Old Jul 18, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
hey when u get your 5-speed swap parts, and everything, pm me a list with prices and where u got everything. I myself want to do that..
but then again turbo auto sounds fun... then again a k20 swap sounds good... GAH!! too many possibilities
Old Jul 18, 2007
bullet02ex's Avatar
bullet02ex will become famous soon enoughbullet02ex will become famous soon enough
sounds like a tranny problem but you should check code, still under warranty?
Old Jul 18, 2007
marcuse's Avatar
no warranty as i know of. its got 70k on it.
Old Jul 18, 2007
bullet02ex's Avatar
i see, i didnt know if you had a honda care or anything. well maybe it will just be time to swap to the 5 spd ! manual trans ftw
Old Jul 18, 2007
definitely go to an autozone, pep boys, or whatever and get that code checked.. it should be free to get it checked, and finding out what code you're throwing will let you know what's messed up
Old Jul 18, 2007
Rufus's Avatar
Car is running in safe mode. Few things could cause it. Been there done that. Need to get it checked.
Old Jul 19, 2007
marcuse's Avatar
alright, ill have it all checked out at the zone.
Old Jul 19, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Yeah just like Rufus said, the car is in safe mode, allowing you to operate it, but not to harm itself any further. You can speculate all you want, but getting a diagnostic report will save a lot of headaches.
Don't know what it could be though...
Old Jul 19, 2007
Rufus's Avatar
Technically it's called "limp mode". Mine did it when the Vtec solenoid wasn't getting enough oil pressure because the screen was filled with aluminum shavings. Ya it was bad.
Old Jul 19, 2007
mugenman's Avatar
"mmmBAHHHH" - vtec y0
so what code was it?
Old Jul 20, 2007
marcuse's Avatar
took it last night and used one of their basic lame scanners. Gave me P1259, VTEC Malfunction. I checked the oil, it looked low and dark. I dont know exactly how to clean the Solinoid screen.... So Ima do a search i guess. Anyway, im still swappin the trans. This would explain the random jolts of power i was losing and gaining (vtec) around 5,500
Old Jul 20, 2007
Rufus's Avatar
Ah I can help with this one IMing you now
Old Jul 20, 2007
Rufus's Avatar
Here is what I sent on AIM
[14:24] yo mark
[14:25] This is Rufus on civicforums. Lemme know if you need advice on that code your car is throwing
[14:27] : parts numbered 14,12,21,10 are all connected to the vtec solonoid
[14:27] #10 is the screen
[14:27] #12 is the sensor
[14:28] if you look on the back passenger side of the head, you'll see it. A blue wire comes off of it
[14:38] Anyway, the lack of oil is likely your issue because when the car starts moving, the oil pressure indicated by the sensor sends a signal and vtec engages. With low oil no pressure is created and the car sees trouble and put itself into "limp mode" to protect you from killing it. Fill your oil, pull the ECU fuse under the hood out for about 10 seconds, plug it back it and go drive it again.
Old Jul 20, 2007
marcuse's Avatar
I had the oil replaced..... There was only 2 quarts in it!!?? After, I took it out to Woodward Ave. all night and it ran perfectly strong and normal. Thanks alot to you Rufus for helpin and not just lurking posts like most do. Anyway how in the world would i only have 2 qts?
Old Jul 21, 2007
Rufus's Avatar
I spun a rod bearing and replaced an engine for the same reason. Didn't burn oil and didn't leak oil, however, somehow 2 quarts mysteriously dissappeared.
Old Aug 6, 2007
marcuse's Avatar
im going to clean the screen today.. tips?
Hqly2001
Jul 25, 2015 05:32 PM
jzhartman
22
Jul 23, 2015 10:42 PM
cyc
Jul 22, 2015 01:14 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
