G'Damn Input shaft bearing again!
Old May 25, 2007
civ_nate's Avatar
civ_nate is an unknown quantity at this point
is this problem known as common with our car? is honda doing anything about it? mine goes every 40xxxkms
Old May 25, 2007
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Re: G'Damn Input shaft bearing again!
they only go bad that fast when you slam through gears. If you drive tame it should easily go more then 100k miles. Honda wont do anything about this because its mostly caused by the driver and shock loading the transmission...
Now if yours is going bad that often and you drive like a grandma your tranny probably isn't spec'd out right. In that case I would take it up with Honda.
JMKendrick
Sep 16, 2015 06:17 PM
AffliictiioN
Sep 16, 2015 02:21 PM
tomas6791
Sep 11, 2015 06:47 PM
rainman15
Sep 6, 2015 11:10 AM
