Battery light flashes
Old Apr 26, 2007
Gflow's Avatar
Gflow is an unknown quantity at this point
Angry Battery light flashes
Its only happen since the beginning of the week but while i am driving the interior light (i.e the seatbelt light) pulses. Then when i come to a stop sign or light the car shakes like if it was going to stall out. My rpm meter when this starts to happen goes down to almost the 0. Its just above it. I have to shut off the car and wait a while before starting it up and making it to where i have to be. I have replaced the altenator, battery, dist. cap + rotor, spark plugs and wires, and new belts. the car is a automatic
Old Apr 26, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
Re: Battery light flashes
take it to an auto zone or somewhere they can plug in to the pcm and see if theres a code in it the dealer can tell you exactly whats srong but its not free like auto zone or other places like that
Old Apr 26, 2007
02civic21's Avatar
take it to an auto zone or somewhere they can plug in to the pcm and see if theres a code in it the dealer can tell you exactly whats wrong but its not free like auto zone or other places like that
Old May 1, 2007
Gflow's Avatar
Yea i did that and nothing came up on it. So if you got any other ideas i would really appreciate it.
Old May 1, 2007
AmbulanceMonkee's Avatar
what happens if you put it in park, or neutral when this starts to happens, instead of shutting the engine off??
Old May 3, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
well the battery light indicates the the battery isnt being charged. and you said you got a new alternator? maybe the belt isnt at the right tension. or the alts ground is bad or the wiring harness is damaged. check out the connections on the alternator and make sure everything is connected good.
Old May 3, 2007
2k1_Toaster's Avatar
2k1_Toaster will become famous soon enough
could also be as simple as the battery terminal connectors not having tight connections. I had similar charging problems (new alt and battery) and it was a loose connection.
Old May 3, 2007
Gflow's Avatar
When i put it in park and neutral the rpms go right back up. So thats what i havew been doing when i come to a stop. I also have had the belts put on by a shop and i have already cleaned the battery conections and made sure they were tight.I have had electrical problems witht the car since i got them just not this bad.. So if anyone can think of something else i would appreciate it becuase this is annoying the hell out of me
Old May 13, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
maybe its an electrical problem? maybe bad grounds? check the tension of the belts with your finger by pressing in the center of the belts should be about .25-.40 deflection.
Old May 25, 2007
Gflow's Avatar
Well i figured out that when i drive with my lights on the battery light wont flash anymore... So i believe its an electrical problem with my lights. If anyone knows how i can go about seeing where it comes from please let me know. Thanks everyone
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
MiniMi
May 27, 2015 01:57 PM
trellex
May 24, 2015 04:39 PM
WLakers
May 4, 2015 06:23 PM
