Burnt Valves
Official Rattlesnake Hunter
What can you guys tell me about them?
Other then it generally happens when you go lean in the combustion chamber.
I think I have burnt all my exhaust valves by running 91 octane gas my car its entire life.
Any thoughts on after market valves?
Any thoughts on replacing the stock ones?
How can I tell if I have a burnt valve without removing the head?
Will a compression test prove anything?
So many questions...
Re: Burnt Valves
^ Hmm, I'd be interested to know if there is a way to do this w/o pulling the head. I've been looking for a head, and some of them looks really dark and burnt up, hmm. BUMP!
Re: Burnt Valves
my mechanic said that a "dry" and "wet" compression test should show a loss in compression because of a burnt valve.
Soooooo you technically should be able to "know" you have a burnt valve without removing the head
Doesn’t make me feel any better though…
any input from "civicforums?"
Re: Burnt Valves
You need to find whats making it run lean, after you figure out if you do actually have a problem.
No sense trying to replace things just to make it happen again. And stop running 91, use 87 like the car is built and tuned to run on.
Aftermarket valves wont solve anything, they'll just allow you to rev the car higher, they arent any more durable against poor combustion than any other valve.
Re: Burnt Valves
What the best way to clean valves without removing the head then?
I’m not running lean. I have a random cylinder misfire on all cylinders and I think it’s because the gas I use.
I’m just worried the damage or carbon buildup is too far to fix my misfire…
So I was considering running new valves and different gas...
Should I buy new valves because I have run 91 since day one?
Or run a ton of fuel cleaner through the car...
Boiler?
Boiler?
Re: Burnt Valves
Switching gas wouldnt hurt. A compression test is probably the best way to tell. I've seen ppl recommend using this stuff:
http://www.seafoamsales.com/motorTuneUpTechGas.htm
BTW, I'm getting random misfire codes also.. po300, 301, 302 and 303. My car runs fine though. Seems harder to start and a lil rougher idle until its warmed up some.
This week I'm gonna check out my fuel pressure and see if its within spec.
Re: Burnt Valves
Same exact thing.^^^ When is the last time you changed your plugs?
Well if changing the gas won’t solve my misfire...
I may consider other things.
Thanks for the link! And post back on your fuel pressure.
One of my friends suggested that too.
Re: Burnt Valves
"...slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time."
Ummm is this stuff ok???
Re: Burnt Valves
I'll post back once I check it out.
Re: Burnt Valves
Okay, just checked my fuel pressure and its 42 PSI which is within the 40-47 PSI specification range. So I'm fairly certain its not fuel related, unless its my injectors. I tried to ohm them out but I think my ohmmeter is bad. They do sound like they click fine. Not sure what I'm going to try next. I find it odd that only cylinders 1,2 and 3 get the DTC and not cylinder 4. I had already swapped coil packs around and installed new plugs. Still no luck..
Someone mentioned that his dealer thinks it might be EGR related, but I'm not sure. Anyway... if I find out any more info I'll post back here.
Re: Burnt Valves
Boiler?
Boiler?
When I took apart my spare motor, which had 70K on it, it was pretty spotless in there, I was impressed with how clean it was, so I'd think any grimy stuff in there is an issue, but the first thing is to run the compression, and see whats going on. If its missing, it might be flooding or just not igniting because of the 91 octane gas.... and crud not letting air through. You gotta remember that unless VTEC is engaged, these things only run on 1 intake valve... so its important that air moves through there.
Re: Burnt Valves
Dont know if you have "quick trips" were your at but thats where I buy my gas.
It could be a wile before I get another compression test...
h4ldol
Electronics
28
Aug 25, 2019 07:04 PM
BJB
Sep 14, 2015 11:16 PM
dantheman42
Sep 4, 2015 01:10 PM
