Dimming headlights with A/C, rear defrost, or power windows
Old Mar 4, 2007
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
I was just wondering if it's normal for the headlights to dim a tiny bit when having either the A/C or rear defrost on, or when using power windows.
I don't really notice the dimming on the road, but when parked and the headlights are shining against a wall or similar, I can notice a very slight dimming.
Thanks.
Old Mar 4, 2007
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I used to have this problem...
After I upgraded to a 180 amp Ohio Generator alternator, Stinger battery, and 1/0 wiring, no more dimming!!!
Old Mar 5, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Slight dimming is normal/common. Dimming is usually lessened if you upgrade your grounding wires.
Old Mar 6, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
Dude its Normal ONLY IF YOU HAVE THE STOCK BATTERY ...
I had the same problem when the compressor turns on ... AND its worst when the bass on ur subs kicks in ...
I switched to an OPTIMA YELLOW TOP ... and all those dimming problem are gone ... even with the most powerful bass !!!!
Old Mar 6, 2007
JMUCivic03's Avatar
JMUCivic03 is an unknown quantity at this point
What you are experiencing is a brief voltage drop. In other words, when you have the car on and all your instruments are drawing power, then you hit the AC or the power windows, youre cars electrical system and computer take a second to bring it back up to what your cr considers a stable voltage. Unfortionatly, it is very normal for most car without an upgraded electrical system. By "electrical system", I mean your car's power plant(alternator)/wiring/battery. I wish it was only a problem of the battery as mani says it is, but replacing the stock one with a starter/deepcycle like a yellow top is like putting a band-aid on a blown off arm. If you have a huge draw on your system, like a big sound system, then you really need to upgrade your alternator, do the "big 3" and upgrade your battery. If you have a smaller to medium sized sound system or you are just worried about dimming lights when you hit the power windows, I would start by upgrading your "big 3" to help with the voltage drops. Realistically though, 90% of the cases of dimming lights when you hit a switch in our civics are just simply a lag of a second or so where the electrical system is just slow to catch up and not a case where your electrical system is unable to supply the need power.
Old Mar 7, 2007
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
When I upgraded to HID retros, I also upgraded the harness...so now no more dimming.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
dinsum
May 28, 2015 09:30 PM
beveragemp
May 25, 2015 07:11 PM
