replacing head gasket
im going to replace my head gasket tomorrow. is their a way to slip off the timing belt without having to remove the crankshaft pulley. could i just slide the timing belt off the of the camshaft and stretch it back on? or just loosen the belt tension and remove the belt from the camshaft. either of those two options take into effect that you have the engine TDC on no. 1 piston before removing the belt. thanks for the help
any hints or suggestions?
mrohitredd
18
May 14, 2015 07:35 PM
HondaHomer
May 14, 2015 12:24 PM
hokiedad4
May 3, 2015 10:06 PM
jessicakaybby
Apr 20, 2015 12:11 PM
