Foglights Problem
Old Feb 21, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
Unhappy Foglights Problem
I recently bought a pair of yellow foglights for my 04 civic... they were all good for a week and suddenly one day i noticed they turned OFF and ON by themselves ... for like a split second ... a few days later they turned OFF and I had to play with the switch and they turned back ON ... No from yesterday they just RUN for like 3 minutes and Turn OFF and then TURN back ON and then OFF and then ON and then OFF .................... Im starting to hate EBAY i tell yaaa What could be the problem ???
It came with a so called OEM switch Is it the switch going bad ? or is it something to do with the RELAY ?
Old Feb 21, 2007
Alpha 5's Avatar
Well it is one of the two. SO I would check how secure the switch is and maybe even replace the relay (relays are cheap).
Old Feb 23, 2007
thanks
Old Feb 26, 2007
SDhondarider's Avatar
SDhondarider will become famous soon enoughSDhondarider will become famous soon enough
Check the fuse as well. I had the SAME exact problem as you until it finally just died and they didn't work at all. I checked the fuse. And I had this.
Replaced with a new fuse and they work perfectly. Damn ebay quality...
Old Feb 26, 2007
Thanks man ... Ill definitely check that up !!! damn ... never expected the fuse
Old Mar 6, 2007
Fixed Alas !!!
THANKS A LOT bro !!! ... I took out the fuse and it was in the same condition like the pic u sent neway $2.42 isnt much for 5 new fuses and i was scared that something big went wrong Thanks man !!!
Old Mar 8, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
thats why cars have fuses...to save our ***
Old Mar 8, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
is that the fuse that came with the kit? Check out what the voltage going through the system is because there has to be a problem causing that. If its just a bad fuse from eBay, then its aiight. But if the problem persists, then you should investigate what is going on instead of continuously buying new fuses
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
CivicBR900EX
Sep 5, 2001 10:27 PM
