Steering Wheel Shakes
Old Feb 19, 2007
01civic20's Avatar
01civic20 is an unknown quantity at this point
I have a 2001 honda civic ex 5-speed. And 60 mph or more my steering wheel shakes a lot. Wut are the common reasons y, so i can diagonse it. Thanks!
Old Feb 19, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Basic reasons:
1. Wheel(s) out of balance
2. Alignment issue
3. Suspension parts loose/damaged
4. Snow/ice in wheel
#4 has been pretty common lately...
Old Feb 19, 2007
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
This happened to me once. Turned out that one of my front tired was damaged. The left half of the tire had a big lump on it and caused the steering wheel to shake at high speed. This is dangerous since the tire can pop at any time. Go it check out.
Old Feb 19, 2007
HondaLuver's Avatar
Its a celebration bitches!
blown shock, look for oil on the shock
Old Feb 20, 2007
2k2civicsedan's Avatar
2k2civicsedan is an unknown quantity at this point
If it only does it when you brake then your rotors need turning. I replace mind and it completely stoped.
Old Apr 28, 2008
becampn's Avatar
becampn is an unknown quantity at this point
Re: Steering Wheel Shakes
It is the tires that are out of balance.
Old Apr 28, 2008
yup 99% of the time its a balance issue. either the shop doesnt know what theyre doing, or the weights fell off from not being stuck properly.
Old May 2, 2008
Wpattie's Avatar
Wpattie is an unknown quantity at this point
get your tires balanced, have the guy check to see if the rubber is damaged or pounded, if it keeps happening after that then have the front end inspected. Maybe ya hit a pot hole or something? oh and if you get it balanced, make sure they DONT use stick on weights, make sure they are hammer on weights!!
Old May 2, 2008
stick on weights work, you just gotta remount them with 3M moulding tape and they will not fall so long as the surface was prepped correctly. its gonna be fun trying to pry them off tho. after a week i tried to remove one with a screwdriver and it wouldnt move lol. but yea the sticky weight with foam the shops use is terrible and just falls off. and also most shop dont even clean the rim when they stick it, mine were dirty and they just put them on anyway lol
Old May 2, 2008
Wpattie's Avatar
you can usually get stick ons off with a pressure washer or a flat head screw driver and a hammer, tho I wouldnt recommend the screw driver method if you can see the area just in case ya miss and scratch the rim. The thing I hate about the hammer on type of weight is when companies mount them on the outside of aluminum rims, cuz it causes corrusion on the rim.
Old May 2, 2008
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
Your front compliance bushings are CRACKED... Go chck them out! now!!
Old May 3, 2008
robbclark1's Avatar
Retired suspension supermod.
This thread is over a year old!!
Old May 3, 2008
lmao, and compliance bushing has no effect on shaking, only cornering.
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
