Idle Problem After Throttle Body Install.
JUST BOUGHT A BIGGER THROTTLE BODY FROM GUDE RACING .
AND HAD TO TAKE THE THOTTLE POSITION SENSOR OFF THE FACTORY ONE AND INSTALL IT ON THE UPGRADED ONE.AFTER THAT I HAVE HAD A CK ENGINE LIGHT ON FOR THROTTLE POSITION SENSOR PROBLEM. DOES ANY ONE KNOW HOW MANY VOLTS THE TPS SENSOR SHOULD BE AT AT IDLE .
IF ANY ONE CAN HELP. PLEASE LET ME KNOW .THANK YOU .
TPS at WOT should typically be at 5 volts! Also, last time I checked honda riveted the TPS to the throttle bodies. So if you had to remove it you might have damaged it? What was the exact code?
The Code Was A Po507 , The Tps Volts Are Set At .50 And The Map Is At 1.98 Volts. I Beleive The Iac Valve Is Faulty ,used The Hds System From The Honda Dealer And Tested The Iac Valve . Failed The Test. Will Replace Tomorrow And See If It Cures The Idle Problem And Completed The Idle Learn Procedure.
Re: Idle Problem After Throttle Body Install.
Because only thread from back in the day were about performance and people trying new things.
davidpaustin
Apr 29, 2015 02:23 PM
mievil
Apr 28, 2015 11:02 PM
