Headlight issues (stock '01 EX Coupe)
Old Jan 22, 2007
Danman114's Avatar
Danman114 will become famous soon enough
a few nights ago, (first night the weather was really cold in the Northeast) I started my car, and both my headlights wouldn't turn on.
Now, the parking lights and the high-beams both work, but after changing out one of the bulbs, I have come to the unfortunate conclusion that the issue is not with the bulbs.
I have not taken it to Auto-zone to get the codes read, though that is the next step (after work tonight), but I was wondering if someone could provide some insight as to what would cause this and how much it could be to fix.
So far, I believe it is an issue with a switch or a relay in the car, but I am not positive.
Thanks for your inputs.
Dan
Old Jan 22, 2007
CraigW's Avatar
All 01s and some 02s had a recall to repair/replace the headlight switch and/or repair connector wiring at the switch.
The dealer most likely can run your VIN to check it.
If you can find a link to the 7th gen TSBs.... You will find it there.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Erndog81
Oct 31, 2015 03:01 PM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
