hesitation????wants to stall
Old Dec 31, 2006
turbolude's Avatar
turbolude is an unknown quantity at this point
i own a 01 ex d17a7....when cold the car intermitantly hesitates....i work at a shop and i have put the ngk iridiums in it, and performed a combustion service to it.....does anyone have any ideas?????
also intermitantly wants to stall but never does, i have replaced the iac and took car to dealer to have the ideal relearn since none of my 5 scantools will do it.....does anyone have any ideas?????
the only thing done to it is a cold air intake, and custom 2 1/4'' exhaust
Old Jan 1, 2007
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
Your performance mod's sound as though you could need more fuel. However, on my stock engine, I had a slight problem with hesitation when shifting between gears. The engine was hard to start and I started noticing my lights being dimmer and dimmer before starting the car. Turns out the battery died! I put a voltmeter on the battery while the engine was killed, and it hovered around 10 volts! What I believe was happening was that the alternator was charging the system during higher rpms, then when I'd shift and the alternator would turn off, the electrical system would run back down to 10 volts, causing all sorts of strange mishaps (even had the car completely die on me once while jammin' at a mediocre level). But in your case, it's probably got something more to do with your performance modifications.
Old Jan 1, 2007
turbolude's Avatar
its done it since i bought the car stock
Old Jan 2, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Couple of questions:
Manual or automatic?
Does it idle low at a stop?
Have you used any injector cleaner like FP60?
BTW here is the Idle Learn Procedure
winanthony94
Sep 25, 2015 09:05 AM
Skunkone
Sep 24, 2015 04:38 PM
NROD315
Sep 23, 2015 03:46 PM
2.0.0.2
Sep 14, 2015 06:38 PM
thaler4cuse
Sep 7, 2015 08:25 PM
