why is it doing this?
Old Dec 14, 2006
01civicriderex's Avatar
The Random King of the Posts
01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light
ok the other day i ran over a nice sized rock that i didn't see. Right after that my battery light and check engine light came on. come to find out a wire came out of my 02 sensor and grounded on my exhaust and fried my alternator. So $500 later the prob is fixed or so i think. Today i was sitting in traffic and the battery light comes on and the car about dies so i give it gas and it goes off. But now the car is idling low and high. What is wrong. I drive a 01 honda civic ex 5speed. Aem intake, aem power pullys, dc sport exhaust
Old Dec 14, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
check your wires again and also check your new, or i hope its new, alternator and make sure its all good. also check your belts and have an obdII scanner check for codes.
Old Dec 14, 2006
All of the wires seem to be good. The alternator is refurbished. Its not throwing any codes. I'm just lost on this one. And another question why is a alternator for a civic so high?
Old Dec 14, 2006
did u check your belt to make sure it is tight?
Old Dec 14, 2006
yea its tight. also they had to take the power steering pump off to get it and my car is not as responsive as it use to be.
Old Dec 15, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
So when they replaced your alternator did they put your alternator pulley on the "new" alternator? If not, did they at least change the belt to a size that will work with your other pulleys?
The PS pump may not have been replaced as tight as before. Check if the PS belt is tight.
Old Dec 15, 2006
bobsagator's Avatar
Oh, and $500 for an alternator is a rip off! When I installed my alt pulley I snapped the post and had to buy one from Discount for under $250, I believe, well at most $300.
Old Dec 15, 2006
the alternator was only $250 and the o2 sensor was $80. Then labor was $170. And it took six hours to change the alternator.
