what did i do?
Old Dec 11, 2006
ryancivic's Avatar
ryancivic has a little shameless behaviour in the past
what did i do?
well just got the headers in and was driving around testing them and i turned onto a back road and floored it (shifting hard etc) and when i went from 2nd to third the gear shifter jammed and wouldnt go into any gear and the clutch pedal wouldnt come up again. so i slowed down and stopped and then i noticed the clutch pedal is completely loose it doesnt catch anything when i push it down and just stays down. the car does start but wont go into any gear. what do you guys think?
Old Dec 11, 2006
check for a tranny fluid leak.. that'd be your best case scenario.. you prolly broke something tho
Old Dec 11, 2006
ryancivic's Avatar
anyone think that maybe my dc sports short shift adapter did it. i mean that adapter does pull some kind of link really close and tight?
Old Dec 11, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
No resistance at the clutch usually means no pressure in the clutch lines doesn't it? I remember people were having the dropped clutch problem after regreaseing their slave cylinder. Let me look for that to see if it helps you any.
And the shifter adapter shouldn't cause a clutch issue like the hard shifting would.
EDIT: Looks like the dead pedal was from reinstalling the slave cylinder and probably not related to your situation.
Old Dec 11, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
i would check the slave cylinder, and check all linkages and tranny fluid.
Old Dec 11, 2006
tsudocivic2k4's Avatar
tsudocivic2k4 can only hope to improve
LOL this happened to me but with my gas pedal. DUDE its the linkage cable. Check the linkage cable to the clutch. Put it back on and U should be good to go. Ya i did that when I put in my intake. Ya get the manel and look up linkagae cable. HOPE THIS HELPS AMIGO!
