Exhaust Hangers?
Old Dec 2, 2006
MarkieMark's Avatar
MarkieMark will become famous soon enough
Exhaust Hangers?
Well tonight I discovered a new problem. ahh Not a big problem just something
that can get to you.
I noticed that when I rev my car to lets say 1k rpm I hear a a rattle. I told my
friend to put his foot on the muffler to hold it steady and when I revved it to
1k rpm it didn't make the rattling noise.
Is this caused by worn exhaust hangers? I haven't got a good look at it yet due
to being dark outside. I'll take a better look tommorow. If it is the exhaust
hangers I plan on getting these: http://cgi.ebay.com/ebaymotors/Unive...QQcmdZViewItem
Old Dec 3, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
Heat shield first. Then try new hangers.
Old Dec 3, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
its the heatshield. just take the heatshield off then all good . its dead wieght anyway.
Old Dec 4, 2006
MarkieMark's Avatar
thanks guys!
i'll try to this asap.
is there anything i need to know about when removing the heat shield? or is it
pretty much straight forward?
Old Dec 4, 2006
MarkieMark's Avatar
well i did some research.
i found this topic:
http://www.7thgencivic.com/forums/sh...ght=heatshield
the last post againifall was saying just use a screwdriver to bend the heatshield.
how would i go about on doing this? just bend in different places until it stops?
Old Dec 5, 2006
MarkieMark's Avatar
bump
Old Dec 6, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Well, first did you check the heat shield to verify it is making the noise? If so then you should be able to determine where the rattle is coming from and use the screwdriver to create some additional space between the manifold and the heat shield, or whatever the heatshield is vibrating against.
Old Dec 6, 2006
MarkieMark's Avatar
are you referring to the header heatshield?
or the muffler heatshield?
well the noise is coming from the muffler. i'm guessing it's the exhaust hangers
because they look really loose.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
