Rear Driver Side Tire bouncing???
Old Dec 1, 2006
90babyblue's Avatar
90babyblue is an unknown quantity at this point
Now when I was driving my car the other day which is a 03 lx coupe...I thought i felt and heard the rear tire bouncing?? Well I had my friend take the car for a drive and I followed him in his car. Well I was right and the rear driver side tire is actually bouncing up and down while driving.....I have no idea why this would be happening...They are brand new tires and the rims looked fine. now my question to you is what would make this happen?? Thank you in advance
Old Dec 1, 2006
Zzyzx's Avatar
Autocross Junky
miss-balanced wheel.... One of the weights probably fell off, so take it back to the tire shop to get balanced again.
Old Dec 1, 2006
Buds302's Avatar
Buds302 will become famous soon enough
your shock/strut is busted. the spring makes it bounce but the strut deadens the bounce. if the strut fails, then the entire thing will bounce up and down.
Old Dec 1, 2006
charcoalex's Avatar
charcoalex is an unknown quantity at this point
agreed. check the suspension for a busted shock. if its leaking or anything and then check your springs.
Old Dec 1, 2006
90babyblue's Avatar
Thanks....I am going to check out the suspension this weekend.....how can I tell if the shock is busted?? just take the wheel off and see if the shock is busted....i probably answered my own question. LOL anyways thank you
Old Dec 1, 2006
charcoalex's Avatar
they leak and if you can push it together with your hands its busted.
Old Dec 2, 2006
streetglower's Avatar
how bad is the bounce. I agree with zzyzx, sounds more like a statically imbalanced wheel. you can havea tire dynamically imbalanced or statically imbalanced. static imbalance will cause the tire to hop up and down. check the balance of the tire.
Old Dec 3, 2006
greeen01civic4d's Avatar
could also be a slipped belt inside the tire, especially if you feel the bounce at all speeds, especially slow speed, most times you cant feel an improperly balanced wheel at low speeds, so slow speed bounce is probably a slipped belt, any tire technician should be able to tell. i deal with this type of thing all the time... good luck, if belt is slipped, you should have a fairly large bump on the tread of the tire
Old Dec 3, 2006
Buds302's Avatar
jack the car up. if you kick the tire downward and it bounces or if you can move it in any direction with your hands then the shock is busted
Old Dec 3, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i am also leaning toward the slipped or broken belt...i've seen unbalanced tires wobble or vibrate (felt at the steering wheel, more severe if it's a front tire) likewise, look for a bump on the tire tread or sidewall.
Old Dec 3, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
its probably either a seperated tire, unbalanced whell, bent rim, out of round tire, or bad shocks, go back tot he place where u bought the tires, and heve them check for speration or bent wheels, they will usually do this free, if it is either of these,t hen they will usually replace the tire for free.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
ImmortalEX
Oct 31, 2001 10:00 PM
