RPM's above 5k drops back to Zero!
Old Nov 19, 2006
UltimateWarrior's Avatar
Pimp My Ride!! Please!
UltimateWarrior is an unknown quantity at this point
Question RPM's above 5k drops back to Zero!
I discovered if I sit idle and rev up the RPM's once it gets to about 5k the engine cuts out (does not stall but drops to normal) and goes back down again. What the?? I can't hit my "Vtech" RPM's! Any ideas?
I never see these numbers when on the road cause I don't really speed or go above those RPM's.
Old Nov 19, 2006
Maybe fuel filter? Something wrong with my engine?? Yikes!
Old Nov 19, 2006
greeen01civic4d's Avatar
could be the vtec controller, or ecu maybe, is it manual or auto?
Old Nov 20, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
May have some clogged injectors since you "never see these numbers when on the road." It is good to hit high RPMs at least occasionally to clean out the carbon and build-up. Try some FP60.
And BTW, it's vtec not vtech. This is vtech:
And also BTW, our vtec's engage around 3k so hopefully you do get into your vtec RPMs.
Old Nov 20, 2006
I have an Auto. And, what is FP60 and where do ya get it? I use Marval Mystery Oil once in a while for my gas treatment.
Old Nov 20, 2006
Axe Man's Avatar
Axe Man is an unknown quantity at this point
There may not be a problem at all...since you stated that you have an automatic transmission. Many vehicles have built into the ECU a rev limiter that prevents you from reving above a certain RPM if in neutral or park. I'm not sure if Honda has this feature but I know some Fords do. Some even as low as 3000 RPM max if not in gear.
One way to settle this is to bring it up over 6000 RPM in either first or second gear. If it doesn't cut out then that pretty much confirms the ECU has neutral rev limiting software built in.
Old Nov 20, 2006
Will try it out. Thanks! Good point.
Old Nov 21, 2006
bobsagator's Avatar
FP60 from Lube Control. There are several threads on it in the Fuel, Oil... Forum. But I agree with Axe Man, probably ECU since it's an auto.
Old Nov 22, 2006
You nailed it man. It appears there is some built in limiter cause when I am on the road in a lower gear I can max out the RPM's. Hmmmm... I never noticed this before! I guess everything is fine. Thanks.
winanthony94
Sep 25, 2015 09:05 AM
deanaZoom
35
Sep 19, 2015 12:22 PM
BBrosario
Sep 17, 2015 07:51 PM
Juanb24
Sep 15, 2015 12:39 AM
Bricoleur
Sep 9, 2015 12:23 PM
