Braking from high speed = shake in front end...
shakes
yeah its deffinately from the tie rod end. i replaced the inner tie rod end on my 96 civic and its fine now, if its warped brakes it doesnt matter what speed your doing if u brake hard enough. im a hard core engine braker, i hardly use my brakes and it happened to me, lift the car and shake the tire in and out to see if there is excess play in the tie rod end inner or outer, possibly both if your using bigger and wider rims than stock (you'll blow them out much faster with oversized wheels.)
Touge
May 20, 2015 10:53 PM
anddrrey
May 11, 2015 02:30 PM
pincookie1
May 4, 2015 12:22 PM
