Loose steering
Old Nov 2, 2006
chickenbuster's Avatar
chickenbuster is an unknown quantity at this point
Unhappy Loose steering
Hey there, I just have a question about my steering. Over the last while, it seems like my steering is alot looser that it used to be. I drove my friends new mazda3 and when you turned the wheel even a bit, it responded. It seems like mine is so soft and loose. When I am on the highway, the steerinig shakes some, but not too bad when you go over 110km. Any advice would be great!
2004 Civic LX
2 door
Manual
Old Nov 3, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Have you checked your tire air pressure lately? Low pressure can make the steering even more slushy than usual. It may also account for the wheel shaking at higher speeds. Check the pressure and the wear since it may be a slight alignment issue also.
Old Nov 5, 2006
The pressure in my tires is right, what else could it be?
Old Nov 5, 2006
streetglower's Avatar
your best bet is to make sure everything on your suspension and steering is tight.
Old Nov 5, 2006
tfnaaf's Avatar
BLDNPSI Mod
steering wheel shakes most likely from an out of balance tire/wheel. The loose feeling could be from the tire just being plain OLD. As tires age and get driven on the side walls get weak and soft and can cause a loose feeling. And also what Streetglower said is also a likely senario
Old Nov 6, 2006
Buds302's Avatar
Buds302 will become famous soon enough
im not sure this might be the problem but check the tie rods.. ive replaced mine in my 90 hatch then a week later had to replace the new ones cause they broke...i think i got a bad set..?
haloway13
Nov 6, 2015 10:43 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
MamaBear2015
Sep 7, 2015 06:00 PM
rainman15
Sep 6, 2015 11:10 AM
