Couple problems ever since ran over curb..
Old Oct 31, 2006
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
Well here's a few things I noticed has been happening ever since I turned a bit too early backing out of a driveway and the front part of my car came off the curb (rly hard too, my bumper on the bottom is all broken) and I really couldn't tell how big of a drop it was because it was entirely covered in leafs
1. When I'm at a dead stop or going VERY slow and turn the wheel, I will hear knocks. Sometimes 1 sometimes 5 in a full turn
2. If I hold wheel straight, car will go straight. But if I let go of the steering wheel, the steering wheel will ever so slightly set to the right, kinda like it's 'middle/set' position. Maybe half an inch but it's enough to make me go accross lanes if I'm not holding onto the wheel. I'm thinking it's the steering rack...but I don't know
3. When I reverse, the steering wheel will turn to the right 1/8th - 1/4th of 360 degrees. I don't remember noticing that before. But then again, ever since the curb I have been paying a LOT more attention to how my car reacts
Thanks for any help
Old Oct 31, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
chances are you might have busted the balljoint or whatever... as for the pulling you need an alignment..
go get the alignment ($50-$80) and ask them to take a look and see if anything else is busted
Old Oct 31, 2006
SOHC_VTEC_pwr's Avatar
SOHC_VTEC_pwr is an unknown quantity at this point
your suspension is shot you will prolly need tie rod ends maby contrl arms or ball joints. Just have a shop look at it and they can tell you whats need to be done. Its dangerous to drive like that b/c if a ball joint goes out, you loose all control and could possibley hurt yourself or others.
Old Nov 2, 2006
karizzle's Avatar
Pinkslip Racer
shiiiit, at least my car will be away as of friday. winter beater comes out which i couldnt care less about
DouglasTheGreat
May 27, 2015 11:23 PM
dragonsblood
Apr 27, 2015 12:28 PM
ImmortalEX
Jan 2, 2002 08:45 AM
CapYoda
Nov 29, 2001 07:37 PM
