engine eating up alot of oil (UPDATED!!!)))
Old Oct 29, 2006
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
hye guys, i need 7thgeners help
i change oil every 3k. and when i did my last oil change, i only got back about 1 1/2 quartz of used oil. I usually get around 3 1/4 quartz.
so a sudden jump from 3 1/4 TO 1 1/2 quartz of used oil....is a big difference.
how come my engine all of the sudden ate up so much oil.
HELP PLZ
OK after 2 more thousand miles since last oilchange....the oil level is quite good...hasnt changed since (1/5" above the second dot). but the oil color is dark/black ish. car still smells like usual
Old Oct 29, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Check your compression.
Ive been burning a half quart a week for over a year now. I used some engine restore and its down to a 1/4 of a quart now.
Old Oct 29, 2006
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
headgasket
Old Oct 30, 2006
streetglower's Avatar
either you have a oil leak somewhere. or like above you are burning oil. an easy way to tell is look at your tail pipe, is it black and wet with oil? Also have a friend get behind you and follow you while you drive, if blue smoke comes out, your burning oil. but yes a compression/cylinder leak test will tell whats going on.
Old Oct 30, 2006
thx, man will do that compression test today.
yea a mechanic also tell me to add in this engine restore liquid thingy every 1500 to see if anything changes.
its weird becuase no smoke of anykind comes out of my tailpipe
Old Oct 30, 2006
puidokas's Avatar
The only time i actually see smoke is at night. Have someone drive behind you with there lights on. Drop it in a lower gear and floor it, usually i can see the smoke in my rearveiw then. Ive tried many additives, but only the engine restore actually worked.
Old Oct 31, 2006
SOHC_VTEC_pwr's Avatar
SOHC_VTEC_pwr is an unknown quantity at this point
Check for leaks man it could be anything from an oil pan gasket an oil filter a drain plug, valve cover gasket, piston rings. Also everytime you change your oil you have to get a new crush washer for the drain plug from honda b/c its a one time use deal b/c it crushes every time its used. You can get by with the old crush washer but not recommended. But oil burning will be noticable at high rpm's more. Jus sit and rev it hard a few times and you will see a white cloud with a blue tint of smoke come out the tailpipe if it is indeed burning. If thats the case then you could try that restore stuff but im skeptical. The perfect fix is a teardown and ring it.
Old Nov 1, 2006
ok i think indeed the my oil is burning oil....smoke does come out....but it was white....couldnt see any blue at all....had my brother double checked too...and he saw only white smoke comes out
Old Nov 3, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
you could also always just check yer oil from time to time.. since yer changing it every 3k (good job) it should still be prettymuch a nice golden brown (almost new looking) even at 3k... take a look at yer dipstick before you bring it in next time.. if yer burning oil it will be.. well.. darker and a lil burnt looking
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
F1wanabe
Apr 27, 2015 11:06 PM
deus-ex
Apr 13, 2015 12:29 PM
Grey
16
Jan 27, 2002 11:34 PM
civiccowboy
Nov 19, 2001 03:44 PM
