clutch/release fork problems? what a bad day...8(
Old Sep 10, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
my clutch was squeeking and i was gunna just lube the slave cylinder rod to stop the squeek but i ended up taking everything apart. The problem i have is that the rod does not go back in properly
Everything goes it normally but when i try to put the bolts back into the block that holds the slave cylinder, it does not align properly because of the rod.
Also, i believe that the release fork seems kinda loose, I didnt really see how stiff/loose it was in the first place but now that i feel it, it doesnt really have much stiffness to it.
I dont know whats wrong with it, anyone have any input?
Old Sep 10, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
the fork will seem loose, mine did to. But it worked out fine. The bolts wont line up now? how?
Old Sep 11, 2006
rice4lyfe's Avatar
im not sure if the slave cylinder isnt pushed in all the way but the rod that pushes the fork seems too long and when i put everything back together, it pushes the cylinder too far back, and it doesnt wanna align. Anyways, i brought it to a friends shop to check it out, im pretty sure it just needs a good bleeding and the piston will go in.
Can anyone check how far the piston in the slave cylinder goes in?
Im just glad that the fork isnt messed up, cuz then it'll be a pain to take apart the tranny. 8(
Old Sep 11, 2006
open the bleed valve with the clutch pedal down and push the rod back in. Then bleed your little heart away. done.
Old Sep 11, 2006
rice4lyfe's Avatar
i tried that, how far does the piston go in?
Old Sep 12, 2006
all the way to the base, you are going to push alot of fluid out so keep and eye open when you are doing it.
beveragemp
May 25, 2015 07:11 PM
vtec_concept
May 24, 2015 10:27 AM
pantdino
15
May 13, 2015 02:22 PM
dooner24
Apr 14, 2015 07:51 PM
Russps
Nov 8, 2001 02:00 AM
