Clutch Alignment Problem
Old Sep 8, 2006
shifoe's Avatar
shifoe is an unknown quantity at this point
So I bought my 04 DX coupe used. And later found out there was an accident on te left front fender that was worse than originally thought. Anyway, there are a few problems, the hood is off alignment on the left side, but more importantly my clutch is out of alignment.
It rubs against the hole through the firewall and I have tried using lithium grease but even that is not enough. So I have a feeling it is totally off alignment. Can I fix this? Or should I take it to the shop? It's under warranty but Honda won't cover it. Any ideas?
Old Sep 8, 2006
skipbarber's Avatar
are you saying that because it sqeaks and you feel resistance letting off of the pedal? if so, it aint due to the wreck, 7thgens have have that problem since 01.
Old Sep 8, 2006
shifoe's Avatar
Yea that is what I've got. But the Honda guy claimed the clutch wasn't aligned. But he was kind of a doushe. :P For example he wouldn't look at my radio because there were scratches on the dash...But has anyone come up with a solution to the squeeknig it is really annoying, but I'm sure alot of you know. Any good spots to lubriate the clutch?
Old Sep 11, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
I am really confused, how is your clutch rubbing the firewall. The clutch is in the transhousing. Go to the slave cylinder and put a bunch of grease on where the pin of the slave cylinder goes and meets with the level which in turns goes to the throwout bearing. Without pulling the trans you cant get to the other places to grease.
honda200192
May 31, 2015 05:57 PM
dinsum
May 28, 2015 09:30 PM
bsmiley
Apr 27, 2015 01:27 PM
dret
Canada West
Jan 8, 2002 03:05 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
