Obd P0304
Old Sep 6, 2006
fondahonda's Avatar
fondahonda is an unknown quantity at this point
Obd P0304
no 4 miss fire
cleared it once and came back two days later
where do I start
checked the plugs seemed to be OK nuthin funky
Coil?
injector?
scan?
what?
thanks for all the great info you guys put up for us green horns
fondahonda
Old Sep 6, 2006
PunkingCivic's Avatar
I need TP for my bunghole
Found this: http://www.obd-codes.com/trouble_cod...e-detected.php
P0304 Code - Cylinder #4 Misfire
Technical Description
Cylinder #4 Misfire Detected
What does that mean?
A P0304 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #4.
Symptoms
Symptoms may include:
  • the engine may be harder to start
  • the engine may stumble / stumble, and/or hesitate
  • other symptoms may also be present
Causes
A code P0304 may mean that one or more of the following has happened:
  • Faulty spark plug or wire
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Running out of fuel
  • Poor compression
  • Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Old Sep 6, 2006
fondahonda's Avatar
it only idels rough on cold starts
after warm up no symtoms
leaning to the coil pack or injector
how would I check either of those components?
Old Sep 6, 2006
streetglower's Avatar
easy way to figure it out is swap the coil from cylinder 4 to cylinder 3 or whatever cylinder, clear the code and when it comes back if the misfire is on another cylinder then the coil is defective. if the misfire stays on the same cylinder, do the same with the injector or test the resistance of the injector.
burnyd
ECU Fried
May 24, 2018 10:44 PM
JetsterDajet
52
May 8, 2016 12:11 AM
99BoostedSi
Sep 7, 2015 04:49 PM
martinsmartin
Aug 15, 2015 07:34 PM
Klame9420
Aug 13, 2015 06:00 PM
