All my engine oil is gone!!!!!!!!!!!
Old Sep 3, 2006
mrb420's Avatar
mrb420 is an unknown quantity at this point
Ok, so I changed my oil, just like the hundred times I have before. After refilling with the new oil, I let the car run for a few minutes. No lights came on and everything ran smooth. After shutting off the engine, I checked the dipstick and it was completely dry! I checked it several more times, with mixed results, sometimes dry, sometimes ok. I let the car run somemore, and checked it again. I got the same results. So, I backed the car up and drove it forward to see of anything happened, and this time the Check Engine light came on. I checked the oil one last time and the dipstick looked ok.
No oil is leaking under the car and I put in like 3.5 liters of new oil and a new filter.
Anyone know why the dipstick comes out dry?
Why did the check engine light come on?
(it is still on) I think i have to reset it with the analyzer.
Could it be the oil pump?
*Note: the oil pressure light never came on...
Old Sep 3, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
check the code.. goto autozone they do it for free. report back what the code is so we can help you diagnose it.
Old Sep 3, 2006
when checking oil, car should be cold, or at least sitting off for 10 minutes.
Old Sep 3, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
cold and make sure all the oil has settled because it cna take a few mintues for it to go through the engine/ filter so that you can get the right results
Old Sep 5, 2006
solar's Avatar
solar is an unknown quantity at this point
According to the owners manual, you're suppose to check the oil when the engine is warmed up to operating temp. Either way, checking it when it's hot or cold, you should still have oil on the dipstick reguardless.
As far as where the oil went, thats a strange one, that much oil can't hide anywhere, unless the head gasket has a major leak and the oil went into the cooling system.
Old Sep 5, 2006
um i think warmed up is trans oil. im pretty sure engine oil it says either cold or 10 mins after the car is turned off.
Old Sep 5, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
I mean, 4 quarts of oil poof? Laydown some cardboard and pull your car ontop. Pull the drain plug, and drain out any oil thats in there. Then put all new stuff in and check for leaks. if you see any oil anywhere coming out you know you have a problem. (I mean you still have a problem because you are throwing a code). Check your coolant to.
Old Sep 6, 2006
solar's Avatar
It really doesn't matter; warm, cold , or hot, there should be oil in the safe range on the dipstick.
(10 minutes after the car is turned off the engine is still hot. )
Old Sep 6, 2006
the whole engine stays warm for a damn long time. I once had to swap out my coolant. 4 hours after driving it for 4 hours I went to take out the bolt behind the block to drain the coolant and burned my self. **** stays hot for a long time.
Old Sep 7, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
put a box fan up ontop of the engine blowing down on the engine. It will cool off fast.
Old Sep 7, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
or drive it into yer local pool
but yeah.. hot or cold.. you should have oil on the stick
Old Sep 16, 2006
7kruwer's Avatar
7kruwer is an unknown quantity at this point
Man,,I have the same problem. Today i checked the oil dipstick. It was not oil at all. It was dry. I went to the shop to change the oil. When they open the washer, there were some oil, but how come there was no oil on the dipstick. I asked for any leaking. The dude said there is nothing leak there. Everything is fine..This is the second time it happen. I dont know why. does somebody know?
Old Sep 16, 2006
Can you say burning oil?
Old Sep 16, 2006
againifall's Avatar
Go Team Venture!
yeah... id like to know what yer oil looks like when they drain it... im sorta scared
Old Sep 17, 2006
dalaw's Avatar
Bone Stock!
hot/cold oil levels really don't make a difference, maybe 1 mm diff on the dipstick
Old Sep 21, 2006
7kruwer's Avatar
i checked my dipstick again to make sure it is not cut off and it is not. When i went to the shop and got it drained, it was black (at least that is what i see) but none in the dipstick...interesting huh..hmmm..i m curious and worry
Old Sep 22, 2006
againifall's Avatar
Go Team Venture!
sounds like its burnning the hell out of it..
stand behind yer car and have someone start it (cold start.. aka first start of the day)... see if yer blowin smoke out yer exaust...
yer doin something wrong somewhere.. is it dripping.. maybe its not dripping to the ground.. but its going somewhere and burnning inside the engine....
get it change.. pay a few bucks extra and have them just dump some through to flush it out a bit...
good luck
Old Oct 27, 2006
yamahaSHO's Avatar
yamahaSHO is an unknown quantity at this point
Oil should be checked warm and with the car OFF. Oil will expand when it gets warmer, so the key is to find out what the level is when warm. Can you check it cold, yes, just make sure it is in a safe range. After you turn off the car, let it sit for a minute to allow the oil in the engine to drip back into the oil pan.
If you do not have oil on the dipstick, look closer as fresh oil is sometime hard to see. If there still isn't any, clean off the dip stick, insert it all the way back into the tube and let it sit for a few seconds, pull it out and read it again. Besure to look at both sides as I have all ways found it easier to read the oil level on the back side (of just about every car I've worked on). If there is still no oil, add some more oil, let it make its way to the pan, and check it again.
As for the transmission comment made earlier. On automatics, the fluid should be check warm and with the engine running.
Old Oct 27, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
agreed, new oil is hard to see sometimes. try using a fashlight or a shoplight on te dipstick whn you pull it out and see if theres any oil. i wanna say something else but i cant remember...maybe later.
Old Oct 31, 2006
SOHC_VTEC_pwr's Avatar
SOHC_VTEC_pwr is an unknown quantity at this point
check your oil on a flat surface
MyCivic
Electrical
Oct 28, 2021 11:06 PM
BootyDo
May 7, 2015 04:46 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
Grey
16
Jan 27, 2002 11:34 PM
civiccowboy
Nov 19, 2001 03:44 PM
