Compression test results (good or bad?)
Old Aug 28, 2006
xxxcivic2001's Avatar
xxxcivic2001 is an unknown quantity at this point
So here's the results:
1. 159 PSI
2. 154 PSI
3. 151 PSI
4. 156 PSI
Service manual says should be 135 PSI.
My car has 103,000 miles it.
Why is the compression higher than the book says?
Old Aug 28, 2006
streetglower's Avatar
probably because you have carbon build-up on the tops of the pistons. but as long as they are all around the same, you are fine.
Old Aug 28, 2006
^yup. and good numbers. hey you should be making more power now right? lol
Old Aug 28, 2006
carbon build up? can u explain how that works.
Old Aug 28, 2006
well when the engine works, carbon forms in small amounts as a byproduct and gets deposited on the engine parts. well carbon is very hard and essentially for sake of simplicity becomes part of the motor and decreases the size of the combustion chamber hence increasing compression. now if you dont like carbon try some lc20 from www.lubecontrol.com its good stuff.
Old Aug 28, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
hey gear how would diferent oil change carbon build up?^
Old Aug 28, 2006
lc20 emulsifies carbon and suspends it in the oil until it goes to the filter. its an additive not an oil. i used it in the trans and got a bunch of black gunk on the drain plug that i never saw before so i know it does something.
Old Aug 28, 2006
02BLKCIVIC's Avatar
But oil never touches the top of the piston, that’s my point.
I don’t know....
I have no dough’s at all the stuff doesn’t work; I just don’t think it will change his compression results...
Old Aug 28, 2006
Syke Fu's Avatar
Syke Fu will become famous soon enough
If you have blow by from the rings, then a small amount of oil can get to the piston area.
Try running a good fuel additive like that techron stuff. That won't remove the carbon deposit that is their, but can help in the future.
Old Aug 28, 2006
cb450sc's Avatar
cb450sc is an unknown quantity at this point
You might try taking out your spartk plugs and put in a couple table spoons of seafoam. Let it sit for a good six hours then take it out on the highway at night. I say take it out at night because you won't believe the amount of black smoke that comes out of your exhaust. Your nieghbours may make a phone if yu did it in your driveway.
zaboomafoozarg
May 30, 2015 09:21 AM
Supramk3
May 11, 2015 07:55 PM
Supramk3
May 8, 2015 11:16 AM
BREADFAN
Apr 15, 2015 08:58 AM
dooner24
Apr 14, 2015 07:51 PM
