Exhaust Manifold
Old Aug 21, 2006
V16Civic's Avatar
V16Civic should not be trustedV16Civic should not be trustedV16Civic should not be trustedV16Civic should not be trustedV16Civic should not be trustedV16Civic should not be trustedV16Civic should not be trusted
Exhaust Manifold
Can a crack in the exhaust manifold affect performance? I have a crack in mine and it seems as though my car is slower going up hills now.
Old Aug 21, 2006
familycar's Avatar
definately. and depending on where the crack is it can cause you to burn a valve if air gets sucked in through the crack. the added oxygen can cause a increase in temperature.
Old Aug 21, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
do you have proof fam???
a link, document, or anything???
Old Aug 21, 2006
V16Civic's Avatar
When I put the gasket back on do I need a sealer? Also, are those eBay exhaust manifolds any good? I am not looking for mroe power than stock, but would like to get it back to at least enough power to make it up hills going 70 without having to shift into 3rd gear. I have a 2001 LX with a 5-speed.
Old Aug 21, 2006
02BLKCIVIC's Avatar
NO.
NO.
No disrespect but you should have bought the EX with Vtec.
not much you can do man...
exhaust will just help your car breath better...
good luck!
Also no disrespect Fam I just want documentation
Old Aug 21, 2006
familycar's Avatar
no sealer just a new gasket. no the ebay manifolds arent worth a dime. and the only way to do a smog legal header on a lx is to do an entire ex exhaust conversion. this is the route i did and maybe got 5hp if i was lucky. but i did spend almost $1k yay!! no seriously dont bother. if anything get your piping diameter increased with a dc5r(rsx type r) muffler...
i have seen it happen. experience will tell the tale. it happened to a friend on his s10 with a blon manifold gasket. cats can also go bad if there are leaks around them. when oxygen is intorduced to heat it makes more heat. i am sure you know the basics. i did a quick search whiel here at work and couldnt find much for you. but here is a short moention on a alfa romero motor
http://www.international-auto.com/in...?fa=ad&aid=185
Old Aug 21, 2006
02BLKCIVIC's Avatar
ok ok!^^^
second question...
can a burnt valve cause a mis fire??
Or can an exhaust leak cause a cylinder mis fire??
Fam??
Old Aug 21, 2006
familycar's Avatar
ok ok!^^^
second question...
Fam??
a burnt valve can cause a misfire due to high combustion temps this is one of the problem i experienced with my integra before i swapped the b20 in. as far as an exhaust leak causing a misfire i am not 100% because i have never run into that problem. but it could be possible with the right scenario. including the cat being superheated and causing a bad signal form the o2. or if the leak was near the head.
Old Aug 21, 2006
V16Civic's Avatar
NO.
NO.
good luck!
What kind of modifications can I do with an EX VTEC versus the LX? I drove a 2005 Special Edition earlier this week and it felt just as slow as my LX. Both 5-speeds.
NO.
NO.
good luck!
What can I do with an EX that I couldn't do with an LX? They are both about the same when it comes to hill climbing power, right?
Old Aug 22, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
The ex is somewhat stronger up hill. And plus an ex is more powerfull and different gearing allows for better accelleration!!!! You will find more for an ex as far as exhaust products go. Ex stock 4-1 header flows almost as good as a DC, but an lx can pick up a little more with a header because of the design of the crap stocker part. EX is the way to go, but not because of vtec, because it is more powerful period.
Old Aug 22, 2006
familycar's Avatar
just do a vtec headswap if that is the case it will yeild an instant 10hp
Old Aug 22, 2006
02BLKCIVIC's Avatar
I love my Vtec.
But civydcex broke it down pritty well.
Ill take some pics with my camera phone Fam...
Im concerend I may have a burnt valve because of a crack in my hearder.
Is there any shure fire way too tell if you have a burnt valve???
Without taking off the head??? Fam?? Anyone???
Old Aug 22, 2006
familycar's Avatar
Is It Burning Oil???
Old Aug 22, 2006
02BLKCIVIC's Avatar
nope.
I have had a randome cylinder mis fire for two years.
Every three days I clear my check engine light.(It runs WAYYY better with the light off)
Then you mented burnt valve sooooo I thought maybe its maybe just maybe I have a burn valve?
I also think it could be a clogged cat...
dont know.
Old Aug 22, 2006
familycar's Avatar
if you had a burnt valve you would be burning oil. plain and simple. a clogged cat probably wouldnt cause a misfire unless it was really bad and holding back a bunch of back pressure. and in this case you would notice a huge loss in power and resetting the ecu wouldnt correct it. i would be looking into th eignition system. that is the most common reason for a misfire. if you have a digital volt meter then check all your signals at the plug wires. and maybe try a new set of plugs. did this start to occur afer the vafc install and tune?
Old Aug 22, 2006
02BLKCIVIC's Avatar
all happend after the aftermarket exhaust.
cel comes on.
If I dont errase it it goes away after the the fifth day.
All this was happening before my vafc & tune.
Ignition is fine Iv never been able to solve my mis fire!
EVER!
Old Aug 22, 2006
familycar's Avatar
if its tuned and its still doing it its probaby an ignition wire!
Old Aug 22, 2006
02BLKCIVIC's Avatar
Ill have to test apmidge or currant strength. (or what ever its called)
Also Im gona have to have another compression test too.
Burnt valve would come up during the compresssion test correct?
any other test you recomend?
Old Aug 22, 2006
familycar's Avatar
yes a burnt valve will cause compresion loss, which would also result in a loss of power. if you dont feel a loss in power then its a random misfire probably caused my the wires or ignition system...
Old Aug 22, 2006
02BLKCIVIC's Avatar
meah due time fam...
Ill run these tests when I get a chance.
Some day Fam youll see a huge thread on
how I fixed my misfire!!!
Some day..
Thanks sir!
Old Aug 22, 2006
familycar's Avatar
no prob!!
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jdh022764
18
Nov 3, 2015 06:44 AM
TheRiddicles
Sep 21, 2015 03:34 PM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
