help?!
Old Aug 12, 2006
whitecivic03's Avatar
whitecivic03 is an unknown quantity at this point
help?!
how do you turn the " maint. req. " light off?
i know you have to hold something in or something like that, anyone know?
i have a 03 civic lx.
thanks.
Old Aug 12, 2006
MidnightCivic's Avatar
Your manual should tell you..a little reading wont hurt you
Old Aug 12, 2006
TitoTheNightKid's Avatar
TitoTheNightKid is an unknown quantity at this point
you have to reset the ecu just on hook the battrie for like ten minutes the hook it back up
Old Aug 12, 2006
CenZ's Avatar
PWIT
no dont do that, it will erase everything. like all presets and if you got a stock headunit you would have to put in the code again its a PITA. i wanna know too. i dont have my manual.
Old Aug 12, 2006
yea i would read the manual but i got my car off of someone else and they didnt have the manual :/
Old Aug 12, 2006
With your engine off you press and hold the reset button located on your instrument panel. Then you turn ure ignition swtich on while holding the reset button for approximately 10 sec untill it turns off.
Old Aug 12, 2006
yea ive tried that didnt work. i just read a post somwhere on here that says to pull the #6 fuse in the under hood fuse box for 10-20 seconds, put it back in and start the car. that will reset the ECU
Old Aug 12, 2006
Dont kno then i dont recommend you pulling your fuses if you dont kno what there for..and if you do that you might aswell unplug your battery.
Old Aug 12, 2006
eh, idk. maybe ill just leave it alone. well thank you.
Old Aug 12, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
http://www.7thgencivic.com/forums/sh...d.php?t=174951
Old Aug 12, 2006
lol. hold tripmeter down, turn car to ON position, wait 20 secs, start car, let go. done. and dont say it doesnt work i just did mine.
Old Aug 12, 2006
thanks i found the post about it after i posted (sry)
i just did it , and it worked !! thanks
Last edited by whitecivic03; Aug 12, 2006 at 11:02 PM. Reason: Automerged Doublepost
Old Aug 12, 2006
RHCP0801's Avatar
gearbox took the words right out of my mouth
Old Aug 13, 2006
streetglower's Avatar
I am suprised this question still gets asked.
