A/C Lag
Old Jul 31, 2006
jiggaman2g
Guest
Posts: n/a
A/C Lag
Hey I have a 2002 civic and everytime I turn on the A/C and start to drive, taking off from 1st the car creeps and then kicks in, by this time its time to switch to 2nd, by then it doesn't feel too bad. Is this normal or do I need to check something out?
Old Jul 31, 2006
its called having a slow engine. it needs 10-20whp to drive the ac compressor. now if you press the gas hard, the ecu will turn off the ac until you ease off.
Old Jul 31, 2006
lumina5201's Avatar
lumina5201 is an unknown quantity at this point
how much hp does it take to run power steering?
Old Aug 1, 2006
2-5 whp max. if you took off the belt, you prolly wouldnt even feel a difference in power.
Old Aug 1, 2006
jiggaman2g
Guest
Posts: n/a
Thanks for the info, I guess I'm going to deal with it until I do my RSX swap.
Old Aug 1, 2006
solar's Avatar
solar is an unknown quantity at this point
20hp is a reach, a normally functioning A/C compressor shouldn't pull more than 5 to 10 hp, it just depends on how well your system is working.
Old Aug 1, 2006
on the civic si, someone dynoed the difference and it was right around 20whp. i know hard to believe, i would guess and say 10whp on a regular civic cause any more and id have to get out and push
h4ldol
Apr 24, 2017 08:16 PM
jtcavey
Sep 30, 2015 02:18 PM
tropicola
Sep 25, 2015 07:02 PM
NROD315
Sep 4, 2015 09:22 PM
