Help me out guys!!! Stripped bolt (pics)
Old Jul 29, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Well when I was gona install my ingals "stiffy" I noticed the shop that installed my suspention FVCKED up this bolt!
Now other then going down there & cussing them out...
HOW CAN I GET THEIS BOLT OFF!!!
THANKS GUYS.
Old Jul 29, 2006
30seconds's Avatar
30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light
get that gator grip thing, just look in hardware store...they have tools to help you out
Old Jul 29, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
It looks like a 6pt wrench should still fit over that, although its hard to tell. Could also try vise grips. And depending on how desperate you are, just hammer a socket on, and try to get it off like that, or go to a shop, pay em $5 to weld a socket on, and you can get it off that way.
Old Jul 29, 2006
streetglower's Avatar
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
it may work. never used it, but always needed it.
Old Jul 29, 2006
02BLKCIVIC's Avatar
your the man street!^^^
gator grip or vise grips wont work!
they put it on with an air gun!
its on there real good.
But its not quit rounded off yet, but it will if I continue to mess with it!
Thanks for the quick responce!
Old Jul 30, 2006
cannonfolder's Avatar
cannonfolder is an unknown quantity at this point
I'm not sure if the bolts come with the new install.If so u could always grind the bolt off with a cutting disk right below the nut.
Old Jul 31, 2006
02BLKCIVIC's Avatar
ehhh^ I dont know! what if I fvck up the threads...
Old Jul 31, 2006
familycar's Avatar
no do not cut the bolt!!!!!!!!!!!! i have that craftsman set. i had to use it to get the lugs off on my teg that the dealer didnt have the key for when i bought it. use an open end/close end wrench to turn the nut off and you will have to hammer it on. so you may need a cocket to help with that. but they work good and accomplished what i needed them to!!
Old Jul 31, 2006
If your new kit comes with the bolts that slide in the holes, you don't have to worry about cutting it.
Old Jul 31, 2006
02BLKCIVIC's Avatar
Good to know Fam...
looks like ill be investing in a 13pc set.
Thanks everyone!
Old Jul 31, 2006
familycar's Avatar
if you actually read his post you would see that he isnt installing a "new" set of struts but installing a trq dampner. so he isnt replacing anything. he just needs to loosen the nut and install the trq dampner. so your idea is useless because you didnt read LOL!!!
Old Aug 22, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
Hammer the next closest size socket on and wrench it off!! But a new nut and there you go
Old Aug 22, 2006
7GenEX's Avatar
7GenEX is an unknown quantity at this point
Civy is right I did that and I had the same exact bolt problem you might mess the socket up a bit but if you really need it off then do what civy said
Old Aug 22, 2006
familycar's Avatar
hey guys the craftsman bolt out kit in a sense is the saem type of thing. except it is designed to grab on to stripped bolts. they arent too expensive and will come in handy a lot after you have them. its well worth the money to invest in a set
Old Aug 22, 2006
02BLKCIVIC's Avatar
ummmm I dont want to f*ck up my 13mm socket.
My set only came with one of each socket not two or three.
Thanks tho...
Old Aug 22, 2006
civydcex's Avatar
Go buy a cheap one at auto zone. And a new nut. Only cost ya like 8 to 10 bucks. Better than paying someone to do it for you.
Old Aug 22, 2006
02BLKCIVIC's Avatar
yes.
but with the kit If I EVER strip another bolt Im good to go.
Im getting the kit.
Its just too good of an investment.
insted of just buying more & more sockets every time I strip a bolt...
Old Aug 22, 2006
civydcex's Avatar
No doubt!! I have so many bit and pieces of previous tool sets I bought so it is easy for me to think myway. The kit is great good luck bro.
Old Aug 23, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
same thing happened to mine, I used a triangle file and sat there for about a hour trying to fix the threads. It worked for me.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
LionSpratt
Jan 29, 2017 11:07 PM
Jun 2, 2015 11:54 AM
ImmortalEX
Nov 8, 2001 09:52 PM
wsking77
Aug 29, 2001 05:34 PM
