sputtering civic
Old Apr 8, 2006
bandjthorpe's Avatar
bandjthorpe is an unknown quantity at this point
Angry sputtering civic
my civic is sputtering like crazy.. the timeing is good the #1 piston is up @ TDC it set for 4 months... i ran it for like 24 hrs.. to get all the bad gas out.. put 97 in and a octane booster still runs ruff. my tack doen't work and it is shooting out carbon deposits from the exhaust and ideas what this can be?
Old Apr 10, 2006
Intercooler's Avatar
Intercooler is an unknown quantity at this point
Ignition related. Probably a fouled plug or four. Spend about $80 and get plugs, wires, cap, rotor, etc... Or start with just plugs.
Old Apr 10, 2006
PunkingCivic's Avatar
I need TP for my bunghole
what year is your ride.
More info would help.
Your user profile had no car information to work with.
I'd do a tune up if you haven't before.
Just check/maybe change the air filter and plugs.
And while you are changing those disconnect the battery.
This why, when your done with the replacement/cleaned filter and new plugs, the ride's ecu will have to adjust the air/fuel ratio's
Old Apr 19, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
97 octane and octane booster, wow! Whats your compression 12.1 geez!
Old Apr 19, 2006
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Right, that's what I thought. I'm guessing your combustion is uneven.
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
