Door locks kinda
Old Apr 5, 2006
BrianJ's Avatar
BrianJ is an unknown quantity at this point
Exclamation Door locks kinda
Hey everyone, maybe someone can help me out or explain this to me. Basically my drivers side door does not lock when I use the lock button inside. But...it will lock when I use the keyless entry. Also...if I try to lock it manually from the inside...it still won't lock. The only way to lock it is to use the keyless.
Has anyone else had this problem, or know how to fix it? It's kinda ridiculous. Also..would that be covered under warranty? I'm kind of assuming it would be.
Old Apr 5, 2006
Intercooler's Avatar
Intercooler is an unknown quantity at this point
Are you pulling the handle to lock it manually? If not it won't. If that checks out then it has to be your switch. Swap sides or jumper it and see if it works. If it does then buy a new switch.
Old Apr 6, 2006
BrianJ's Avatar
I'm not pulling on the handle to lock it, actually when I'm in the car and try to manually push down the lock to lock it, it will not go down.
I will try to Jumper it when I get home from work and see if that works. Maybe I need a new door lock assembly?
Old Apr 6, 2006
Have to pull the handle for it to lock manually.
Old Apr 7, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
no.....i thought mine was fkd up too since it would only lock with the key.....go figure. stupid honda makes it so you have to pull the handle to lock the door....
Old Apr 7, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
yeah alot of Hondas, possibly all of them, have to do that to lock it.. whether you are pushing it down manually or pushing the button you have to hold the door handle open. I guess its a don't forget to lock the door/grab your keys reminder safety issue.
Old Apr 7, 2006
BrianJ's Avatar
That ended up being the problem. I didn't have the handle on the door that pulls on the rod that opens the door from the inside. I put it all back together and now it works. Thanks for the help guys!
Sep 26, 2023 06:44 PM
breanna_17
Jul 21, 2015 04:01 PM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
