squeaky clutch pedal
Old Mar 10, 2006
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
soo..my car is an 03 lx 4dr 5spd....and it just hit 30k miles....and when i release the clutch the pedal is squeaky i would take it to the dealer but i dont trust them and to top thing off my headlight blew anybody have this problem..i know its not serious..just annoying....hmmm..what you guys think
edit...^^a lil confusing..i know the headlight and sound are unrelated..haha..i was just venting bout the light
Old Mar 10, 2006
DDragon7's Avatar
There are couple of threads about the squeeky clutch already, try searching.
Old Mar 13, 2006
dacivic's Avatar
dacivic is an unknown quantity at this point
If you bring it to dealer it will cost u 400+ cuz they will say it is the master cylinder. Actually it is the fork that needs to be lube and is not an easy job. Just turn on the radio and ignore it.
Old Mar 13, 2006
thanks...+1 for you....its annoying and i only hear it when i let out the clutch slow..but yeah time to upgrade the speakers
Old Mar 15, 2006
HondCivc91's Avatar
HondCivc91 is an unknown quantity at this point
my clutch started creaking when i push it in slowely. i just got wd-40 and shot it in a couple places under the dash - tried it again and it was fine.
Old Mar 15, 2006
sounds easy enought...will give it a try +1 for you
Old Mar 15, 2006
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
yeah, its a way easy fix. in fact, i did it yesterday during my lunch hour and i still had time to make lunch and watch cops! lol
take off the cover under the steering wheel, the one to expose the fuse box. then under that theres a black panel cover, take that off as well. get down under there and look for where the clutch pedal pushes a rod through a little hole. spray the **** out of the hole as well as on the rod with WD 40. then get a paper towel and clean up the over spray. push the pedal a few times, spray some more. that'll fix the inside noise.
mine still has a bit of a squeak on the outside (engine compartment) but thats an easy fix as well. just couldnt do it on my lunch hour.
i tried just spraying WD-40 up toward the clutch pedal blindly, that didn't work too well, you gotta get up under there and spray where it actually makes the noise.
Last edited by manthatguysfast; Mar 15, 2006 at 01:18 PM. Reason: Automerged Doublepost
Old Apr 14, 2006
asdf54's Avatar
asdf54 is an unknown quantity at this point
alright, looks like im going to try this also
thanks guys
Old Dec 15, 2008
LemmieHill's Avatar
LemmieHill is a jewel in the roughLemmieHill is a jewel in the roughLemmieHill is a jewel in the rough
Re: squeaky clutch pedal
I wouldnt really recommend putting WD40 into where the piston rod for the slave meets the pedal, I would use white lithium grease instead. I had this problem for a while, and it turned out to be the pin that the clutch pedal pivots on. If you go up under the dash where the previous people have stated and look where the rod meets the pedal, and then look .5inch up from that, you will see a pin/ pivot point, lube it up.
Old Dec 18, 2008
jackscivic's Avatar
jackscivic will become famous soon enough
silicone gel spray for the piviot point, and white lithuim for the rubber part. it only needs to be replaced if its leaking fluid. this will be very visible. dont fall for the dealer tricks. its the slow season. they will take any hours they can get.
Old Dec 26, 2008
johnnyboy5000's Avatar
johnnyboy5000 is an unknown quantity at this point
Now that it's gotten a little cold in Las Vegas, the squeaky clutch has come back. It squeaked like two years ago and I used white lithium grease into the master cylinder and that fixed it. Time to do it a again. Get the type with the long straw so you can squirt it inside.
Two years I tried changing the clutch pedal spring to get rid of the squeak, but it still squeaked with the new spring. White lithium grease is the way to go IMO.
Scout1
Oct 5, 2015 01:33 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Klame9420
Sep 7, 2015 10:03 PM
violentpanda
Sep 7, 2015 11:49 AM
tommycanada
Sep 5, 2015 04:59 PM
